Liked 28 Times in 15 Posts
What's the best way to plug the speedometer cable hole on a TH-350? Use an old cable setup or what size plug?
#2 | |
Liked 5,125 Times in 1,953 Posts
I usually use a rubber expandable plug ..Just install it dry. I mean brake clean dry!
Mark
I knew you would know the diameter but where the hell would I find that plug? I'm going to the junk yard tomorrow to finish stripping a 305 short block. What would I need from a TH-350 to plug the hole properly? |
Liked 33 Times in 16 Posts
If you have an old head I would just use it...has an o-ring if I remember right.
Rich Taylor I/SA - 321 |
#5 | |
Liked 8 Times in 7 Posts
how about a metric freeze plug? I'm assuming it's the large speedo adapter rather than the small "bullet"....
without losers,winning means nothing. |
Depending on the size you might consider a boat/livewell type expanding plug.
Sonnax Transmission Parts
Part # 35922-01K. TH350 Speedometer Hole Plug. During high performance rebuilds, the speedometer gear is often removed and replaced by a freeze plug. However, in addition to being used for driving the speedometer, the gear is also critical to lubricating the rear output shaft bushing. This new speedo plug supports the speedometer gear and allows lube to flow as the original design intended. The gear shaft has to be cut to 1.320" long. Cost $24.00 ![]() http://www.transmissioncenter.net/So...uper_Store.htm
Rick Blake 2395 SG, SC, SP |
That being the case then the original stock head would seem to be the way to go after all.
Liked 99 Times in 60 Posts
I will need solid engineering proof about the statement "helps lube rear bushing"
Just consider the units in service with speedo adapter hole plugged yet they experience normal rear bushing service life.
Larry Woodfin 471W |
Liked 239 Times in 114 Posts
The spinning governor provided the needed lube for the rear bushing. This was true for the 700-R4 also. When the transmissions were redesigned to the "e" versions, a hole was drilled that pee'd fluid back to lube the bushing.
