Old 02-09-2014, 12:15 PM   #11
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: TH-350 Speedometer Plug Size
I believe it is safe to assume if one is plugging the speedo drive hole the trans is seeing limited service on the street. That being said the impact of the deletion of said gear will have minimal impact on the lifespan of the transmission or any of it's components.
Rich Taylor
I/SA - 321
Old 02-09-2014, 01:44 PM   #12
Liked 5,124 Times in 1,953 Posts
Agreed..Plus where does the fluid go to on a drag car? ;-)
Old 02-09-2014, 02:49 PM   #13
HandOverFist
On the track in some cases...
Rich Taylor
I/SA - 321
Old 02-09-2014, 03:20 PM   #14
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
Originally Posted by ss3011 View Post
The spinning governor provided the needed lube for the rear bushing. This was true for the 700-R4 also. When the transmissions were redesigned to the "e" versions, a hole was drilled that pee'd fluid back to lube the bushing.
governor is one thing but the speedo gear is another...aside from always leaking and the speedo gear wearing out at the seal,how does it do anything else?
Old 02-09-2014, 09:02 PM   #15
brian schuetta
Liked 28 Times in 15 Posts
Interesting discussion! I found a 87' Caprice type thing in the yard today that the same diameter speedo plug. I took that and cut the speedo cable for the screw on part and put it on the trans. So far so good. First race this weekend. Alignment shop Tuesday. Will sort thru everything that was said here and re-think what I did but I needed the trans to stop leaking right now. Thanks guys.
brian schuetta is offline   Reply With Quote
Old 02-09-2014, 09:37 PM   #16
HandOverFist
Good to go.
Rich Taylor
I/SA - 321
