Old 02-19-2014, 02:13 PM   #1
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Crank for SBF SS/GT?
There seems to be a distortion field between the NHRA rulebook and the Accepted Products guide that either encourages cheating or discourages racing, I'm not sure which.
I was going to go with an Eagle or Scat rotating assembly to build the 302 for my SSGT 68 Mustang but I wasn't sure all the parts they included fit the NHRA specs so I'm going to put it together myself. Pistons I can figure out, Flat top with two notches that don't increase stock compression. OK. Rods. 5.090, no fancy stuff to make them light. OK.
Here's the problem: The rules state OEM or NHRA approved crank only for SS, which carries over to SSGT. When I go to the Approved Products guide, there is a grand total of ONE crank to pick from on a document titled Stock Eliminator Approved Cranks. Is every SBF in SS out there running this crank or am I missing something?
Me thinks I'm missing something...
My instinct tells me I can run any crank with the following dimensions as long as it isn't under stock weight or had voodoo specifically lined out in the rules done to it.
3.00 Stroke
Rod bearing journal: 2.123
Main bearing journal: 2.249
Thanks,
Dale
Dale Shearon
68 Mustang 6394
Old 02-19-2014, 02:32 PM   #2
Ed Wright
Ed Wright's Avatar
Default Re: Crank for SBF SS/GT?
Dale, you need to submit to NHRA the crank you want to use. Might not have to give them a crank, possible a link to the info about it. Talk to your div tech director about it. He can give you the name & number you need to contact.
Those approved parts are listed there because somebody (racer or mfgr) submited them for approval.
Ed Wright 4156 SS/JA
Old 02-19-2014, 02:40 PM   #3
FireSale
FireSale's Avatar
Do I use the Crank Approval form for Stock Elim from NHRARacer? My tech doesn't always get back to me.
Dale
Dale Shearon
68 Mustang 6394
Old 02-19-2014, 02:48 PM   #4
SSDiv6
Liked 1,604 Times in 583 Posts
Dale
This should help you understand the "Do's" and "Dont's" as regards to crankshafts in the regular Super Stock and Super Stock GT classes.
http://www.nhraracer.com/content/gen...9848&zoneid=85
Basically, if your forged crankshaft meets this criteria it should be acceptable for use.
Old 02-19-2014, 02:56 PM   #5
FireSale
FireSale's Avatar
"Constantly looking for smaller and smaller details in our quest for HP..." Yup.
Thanks. I'll save that link. I'm new at this and just want to make sure I understand everything before I drop cash on a part that might get me bounced if I don't get it right. To that end I ask questions.
I'll pick a crank and send the info to Glendora.
Thanks,
Dale
Dale Shearon
68 Mustang 6394
Old 02-19-2014, 05:00 PM   #6
Damn Yankee
Not trying to be a smart a** but I have to laugh at #8
Dale surely you can contact Crower or Bryant. Personally I would speak with Greg at Rody out of Plymouth Mi
Damn Yankee is offline   Reply With Quote
Old 02-19-2014, 05:29 PM   #7
SSDiv6
Why is it funny? In the past I have seen crankshafts that have been dressed up and the surfaces either polished or treated that the seams cannot be seen.
For a Super Stock GT engine you do not need to go and spend $$$ on a Crower or Bryant crankshaft. There are more affordable crankshafts from other vendors that will do the job and more.
Old 02-19-2014, 06:06 PM   #8
Ed Wright
Ed Wright's Avatar
If Scat makes one, for the money that would be my choice.
Old 02-19-2014, 07:00 PM   #9
Alex Denysenko
Alex Denysenko's Avatar
Liked 4 Times in 3 Posts
we have 2 different ones in both of my SS motors one is a crower which NHRA looked at twice and blessed both times the other is a RPM off shore unit a company for which we distribute dollar for dollar we don't really see much difference between the 2 except for the cost the Crower cost was 3 times as much and took F O R E V E R to get they both balanced about the same both increased bearing life
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK
Moneymaker Racing LaPorte Indiana 219-861-1214
www.moneymakerracing.net
Alex Denysenko is offline   Reply With Quote
Old 02-19-2014, 07:07 PM   #10
Ed Wright
Ed Wright's Avatar
Sounds like what he needs to buy.
