Old 03-25-2014, 01:25 PM   #1
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Wanted - Quadrajet metering rods
Looking for secondary metering rods - DM, CF, DG or DF.
Rich Taylor
I/SA - 321
Old 03-25-2014, 02:53 PM   #2
John Musial
Liked 51 Times in 3 Posts
Default Re: Wanted - Quadrajet metering rods
Try here http://www.carburetion.com/quadrajet.asp
John Musial is offline   Reply With Quote
Old 03-25-2014, 03:26 PM   #3
NORMAN BARNARD
Liked 2 Times in 2 Posts
Try www.quadrajetparts.com they have just about everything.....
NORMAN BARNARD is offline   Reply With Quote
Old 03-25-2014, 06:55 PM   #4
HandOverFist
That's where I get most of my parts, but the richest rod they have is AX.
Rich Taylor
I/SA - 321
Old 03-26-2014, 08:27 AM   #5
Alan Nyhus
Liked 799 Times in 236 Posts
Rich, I checked out my stash....nothing richer than the AX's (.397 tip).
The DF and DG's are virtually identical (.340). Other .340 tip dia. rods are the DU, DS and CF if that helps your search. Here's the GM number on a couple of the rods:
-DF: 7048512
-DG: 7048890
-CF: 7044775
The EF's @ .567 are good candidates for lathe turning to what you need. You might want to try Dean Oliver @ Deano's Carbs:
http://deanoscarbs.com/
"That'll never work....."
Old 03-26-2014, 09:15 AM   #6
HandOverFist
Thanks Alan - I may have to have some modified if I don't locate any.
Rich Taylor
I/SA - 321
Old 03-26-2014, 10:40 AM   #7
Dave Ribeiro
Liked 56 Times in 27 Posts
Wink Re: Wanted - Quadrajet metering rods
Rich,
Try allcarbs.com , they carry everything you need for Carbs ....There number is
631-234-8327 , everything from gaskets, jets, pumps , etc.... Cool place, hope this helps ?
Dave Ribeiro 1033 STK
Old 03-26-2014, 12:09 PM   #8
HandOverFist
Thanks for all the info guys...I have been to all the sites, but no luck yet. Recently enlarged the secondary well orifices from .136 to .146 on several test carbs...unsure how that will scale vs given metering rods. I can get a "CC" rod, but I fear that is going to be just too large a jump to be useful. Was hoping to have one set of rods in the above mentioned range to test in several carbs at my next TNT session.
Rich Taylor
I/SA - 321
Old 03-26-2014, 06:16 PM   #9
Run to Rund
Liked 54 Times in 27 Posts
I might have some of them.
Old 03-27-2014, 01:56 PM   #10
DIV3CR
Liked 3 Times in 1 Post
I bought a pair from Quadrajetparts.com last year that are .0300 L
# Q 2600-CC there in my carb now from the end of last year.
DIV3CR is offline   Reply With Quote
