Old 03-30-2014, 12:02 PM   #1
Aubrey N Bruneau
Aubrey N Bruneau's Avatar
Liked 7 Times in 3 Posts
Send a message via Yahoo to Aubrey N Bruneau
Default Ordering New Transmission, but What Gears ?
I sold my 2.83 1st gear Jerico DR4 a few months ago ( thanks to Class Racer ! ).
Time to order the replacement.
I have the new whizzy ( for me anyway ) Advanced Clutch system now.
Obviously, my previous selection of a 2.83 1st gear was a miss-match. Most guys have told me that I need like around a 3.20. When I spoke with the guy at Jerico, he recommended no more than 3.08. His reasoning being, that the engine doesn't rev high enough. Sounded logical. Engine makes peak torque at 4500/4600 RPM
Car scales at 3635
Shifted at 7000
Thru traps at 7200 / 7300
Best previous 60 ft was 1.59
Aubrey N Bruneau 6409 C/S
62 BelAir sport coupe, 409 HP 409
Aubrey N Bruneau is offline   Reply With Quote
Old 03-30-2014, 01:27 PM   #2
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Default Re: Ordering New Transmission, but What Gears ?
What was your SLR with the other first gear? 3.08 seems like not enough. The higher numerical gear the more you can work the clutch and accelerate the car
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 03-30-2014, 01:37 PM   #3
mopacltd
Liked 124 Times in 44 Posts
My thought would be to go to a 3.25 first
mopacltd is offline   Reply With Quote
Old 03-30-2014, 03:18 PM   #4
Bill Belden
Bill Belden's Avatar
I would go with 3.19 first
Bill Belden
Retired Stock Eliminator
[emailSTK1100@comcast.net[/email]
Bill Belden is offline   Reply With Quote
Old 03-30-2014, 04:27 PM   #5
Aubrey N Bruneau
Red face Re: Ordering New Transmission, but What Gears ?
SLR ?
HHMMM...
"single lens reflex" camera ? ? ! !
You have to remember who you're dealing with here... the guy who shows up to increase car count, and give the new guys somebody to beat in the first round !
really don't know what SLR stands for
Thanks, guys. That's what I keep hearing from everybody but Jerico.
torque is pretty good on this engine... 490 ft lb, so I'm thinking recovery might not be such a monumental obstacle.
Old 03-30-2014, 05:26 PM   #6
Rory McNeil
SLR equals Starting Line Ratio. 1rst gear x rear axle ratio.
example, 2.88 x 4.88 is 14.06 SLR.
My Mustang with 3.19x5.13 is 16.36 SLR. I would like even more SLR, but with the steeper 1rst gear, and only a 4 speed, the ratio drops thru the gears get pretty wide. Not as much of a problem for a big engine with good torque, but then you are also pulling a lot more weight.
Also, don`t forget that an engine that doesn`t like a lot of RPM will have less rear end ratio, so to get the SLR more favorable, the only other choice is more low gear. Of course more SLR also increases the chance of wheelspin......
NHRA 6390 STK
M/S 85 Mustang
Old 03-30-2014, 05:31 PM   #7
henrys57wagon
henrys57wagon's Avatar
Aubrey, SLR= starting line ratio. Here is a calculator.
When we raced I was one of the cars to increase count, did get into 2nd round the odd time at division meets.
http://www.wallaceracing.com/calc-slr.php
old 1608 stock racer
henrys57wagon is offline   Reply With Quote
Old 03-30-2014, 05:55 PM   #8
Todd Hoven
Guest
Posts: n/a
Go with at least a 3.19 or higher. The lower the first gear, the lower you can go starting line rpm and use the tq of that engine to get it moving. The higher you leave, the better the chance of not hooking that car. The slower wheel speed, with give the tires a better chance of hooking. IMHO
Old 03-30-2014, 07:09 PM   #9
james schaechter
Liked 1,439 Times in 301 Posts
Consider a 3.19. The 3.29 is a 34/15 gear and is not as strong as the 33/15 that the 3.19 has. Could be a concern with yout torque and weight combo. Plus the 3.19 can easily be converted to a 3.08. Stay away from the 3.17 also. It is a 34/16. The 34 tooth mdg is not as strong. Same diameter gear only one more tooth crammed in.
James Schaechter 3163 STK
Old 03-30-2014, 08:55 PM   #10
Aubrey N Bruneau
This is fantastic info, people... no wonder I come in here !
My combination had a 14.52 SLR. Yes, I did use to leave at pretty high RPM... about 6200.
Never did really hook up.
Have to make a decision pretty soon, so I can get the transmission under way.
