Old 04-11-2014, 01:08 AM   #1
7560 cjp
Guest
Posts: n/a
Default New Aluminum Cylinder Heads for the 396
Has anyone heard that NHRA has approved the use of aluminum heads (The Edelbrock Heads) for the replacement of the CI ones that can be no longer Located? it was said they still had to have the same spec's as the CI ones. (IE; 2.06/1.72 valves, the same cc's and the same intake/exhaust spec's)
Old 04-11-2014, 10:21 AM   #2
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: New Aluminum Cylinder Heads for the 396
There are two new Edelbrock heads on the current list (3/27/14). They are numbers 60547 and 60447. Does this help?
Dale
Dale Shearon
68 Mustang 6394
Old 04-11-2014, 12:42 PM   #3
MAURICE BLENDHEIM
Liked 284 Times in 87 Posts
The Edelbrock 60547 has a 315 runner and is the same as the GMPP "401" head both being Rectangle Port and Legal. The Edelbrock 60447 has a 290 Oval Port runner, but is listed from suppliers (Summit & Jegs) as NHRA Legal and is described as having 2.19 - 1.88 valve seats. Obviously there is more to this, than I would be ready to assume. Could make quite a difference on a 325-350-360HP combination if its reality. MB.
MAURICE BLENDHEIM is offline   Reply With Quote
Old 04-11-2014, 12:48 PM   #4
Bobby Lundholm
Liked 127 Times in 49 Posts
Isn't this for Super Stock only though?
Bobby Lundholm 3516 G/SA
Bobby Lundholm is offline   Reply With Quote
Old 04-11-2014, 01:33 PM   #5
Chad Rhodes
per Edelbrock's website, the rectangle port is legal stock and ss, the oval port is super stock only.
Chad Rhodes 2113 I/SA
Old 04-11-2014, 02:06 PM   #6
Bobby Lundholm
60447 is for the 396/325/350 HP combo's for SS only. Too bad thought I was getting some aluminum heads.
Old 03-02-2015, 10:21 PM   #7
SantinoBlanco
The 60547 heads on summitracing.com says the spark plug hole is moved closer to the combustion chamber by .150 and the NHRA rule book says it has to be in the same location. Not sure how it's an accepted product
SantinoBlanco is offline   Reply With Quote
Old 03-03-2015, 07:10 AM   #8
Pedigo Perf
Pedigo Perf's Avatar
Liked 30 Times in 17 Posts
By adding 10 HP
Pedigo Perf is offline   Reply With Quote
Old 03-07-2022, 05:42 PM   #9
Terry Cain
Terry Cain's Avatar
Liked 231 Times in 107 Posts
Funny how the stocker guys can't use these heads and have to dig thru junk at swap meets, etc. to get a set of heads but the Super Stock racer can use because they can't locate the stock Cast Iron heads.
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 03-07-2022, 05:48 PM   #10
Billy Nees
Liked 7,782 Times in 1,743 Posts
And the rest of us that DON'T have a 396 "have to dig thru junk at swap meets, etc.to get a set of heads" and that's OK?
Somehow, I just don't feel sorry for the poor Stocker guys that run a 396!
Billy Nees 1188 STK, SS
