Old 04-29-2014, 09:24 AM   #11
Billy Nees
Default Re: May Day !! Down a cylinder
Hey Sparkie, check to make sure that you didn't suck an intake gasket into the port!
Billy Nees 1188 STK, SS
Old 04-29-2014, 09:25 AM   #12
philbilly
philbilly's Avatar
Jeff Taylor Is gonna dyno it and figure it for me if I can't get it. He treats me like family. I always feel like I am bugging him. I can't get there till thurs so I am trying to fix it myself. I have sent him all the info I gathered yesterday I will see what he thinks. He takes time out if his business to teach me things over the phone.
Mike T another class racer engine guy has spent countless hours with me giving me info.
I appreciate all you guys do for me. I love turning wrenches. It's something I really don't mind.
Frustrating sometimes but I wouldn't trade this stuff for nuttin!!
philbilly is offline   Reply With Quote
Old 04-29-2014, 09:29 AM   #13
philbilly
philbilly's Avatar
Billy I changed intake gaskets Friday night when I took heads off to check all gaskets!! I am like literally 5 minutes away from pulling the heads off. An just checking valves.
This is a new old head. When I left Florida I had a busted casting.
Old 04-29-2014, 09:31 AM   #14
FED 387
Liked 333 Times in 180 Posts
try another new pug in 7 u might have a bad plug---- or swap 7 plug with another cylinder see if it moves---you just might have a cracked plug tho--FED 387
Old 04-29-2014, 09:31 AM   #15
philbilly
philbilly's Avatar
859 743 1859.
Old 04-29-2014, 09:34 AM   #16
philbilly
philbilly's Avatar
We tried 17 different plugs we sapped wires around we put new in wire cap everything. I worked all night Friday at Indy changing ing everything even carbs.
Only thing I didn't swap is the head from one side to the other. That might happen today.
Old 04-29-2014, 10:41 AM   #17
Dan Lattimore
Liked 154 Times in 37 Posts
Collapsed sealed power/speed pro style oil ring expander will do that and still show good leak . Just a thought ------
66W30POST
Dan Lattimore is offline   Reply With Quote
Old 04-29-2014, 11:04 AM   #18
philbilly
philbilly's Avatar
I can't take it lol. He's is off we are headed to peel son valves check some guides. Number 7 piston looks like it did when it came out of box clean as a pin. Other cyl have little black carbon on them from where they have fired.
Old 04-29-2014, 11:14 AM   #19
Mike Pearson
Mike Pearson's Avatar
Liked 1,945 Times in 586 Posts
What does the intake port look like on that cylinder. It could be a small crack or sand pit in the head casting allowing oil to be pulled in to that cylinder. You could do a vacuum check on that port if your machine shop has that type of equipment. You could have a problem with the oil ring in that hole too. It will leak check good even if the oil ring is not sealed. The expander could be lapped over.
Mike Pearson 2485 SS
Old 04-29-2014, 11:26 AM   #20
R. Thorne
Liked 101 Times in 34 Posts
Phil, is the plug gas fouled (stinks of gas) or oil fouled (you may smell some gas residue but no stronger smell than the other 7 cylinders)? My guess is an overlapped oil ring expander ( especially if it uses those damned Hastings Rings type of expander). Ron.
R. Thorne is offline   Reply With Quote
