Old 04-29-2014, 11:32 AM   #21
philbilly
philbilly's Avatar
Default Re: May Day !! Down a cylinder
I believe it oil. It doesn't smell much like gas. I am headed to pressure check some things. Let u know Results shortly.
philbilly is offline   Reply With Quote
Old 04-29-2014, 11:48 AM   #22
STK1217
STK1217's Avatar
Liked 10 Times in 7 Posts
Originally Posted by philbilly View Post
Chuck we changed plugs and wires several times. I am thinking guide but if guide was wore it would show in leak down?
This is the new head we did fix. I busted one at gators.
Mb is gonna post up pic of plugs for me. I sent him pic of 1 and 7 plug so y'all could see
Just a question, How would a loose guide or bad valve seal show up in a leak down test?
STK1217 is offline   Reply With Quote
Old 04-29-2014, 12:12 PM   #23
philbilly
philbilly's Avatar
I wouldn't think it would beings it's above the seat. Wouldn't the spring hold the valve in the seat good.
If I knew the answer I wouldn't be on here. I am going to tear into the head I don't find nothing obvious I will have the pistons on the bench before I sleep I promise.
Old 04-29-2014, 01:27 PM   #24
gbur
Originally Posted by Dan Lattimore View Post
Collapsed sealed power/speed pro style oil ring expander will do that and still show good leak . Just a thought ------
agree with the oil ring problem
Gary Burr IHRA MEMBER # 1958 Stk 1949
gbur is offline   Reply With Quote
Old 04-29-2014, 01:42 PM   #25
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
I think that is right next step,call me you need anything
Mike Taylor 3601
Old 04-29-2014, 08:41 PM   #26
Dyno
Dyno's Avatar
Liked 693 Times in 205 Posts
I had a broken expander on the oil ring and it pumped oil like crazy. Pull the piston and you will find the problem. Dyno
Old 04-30-2014, 12:06 AM   #27
Adger Smith
Liked 880 Times in 311 Posts
Did you say Speed Pro/ Sealed Power rings?
If they are:
Second ring installed upside down. Reverse twist is pushing oil up the cylinder.
Second choice would be the oil ring expander overlapped.
Have you rotated the firing order on the cap to be sure that there is one firing
cycle that is dead? I had a HEI kick my butt like that!!
Adger Smith (Former SS)
Old 04-30-2014, 12:15 AM   #28
JimL
What distributor do you have in it?
JimL is offline   Reply With Quote
Old 04-30-2014, 03:03 AM   #29
SS Engine Guy
Check valve springs on that cylinder.
SS Engine Guy is offline   Reply With Quote
Old 04-30-2014, 07:32 AM   #30
philbilly
philbilly's Avatar
I have total seal rings. i have msd ignition I have changed every piece of it. I have done everything most has named twice. the piston is clean as a pin guys. there is no oil ,if a ring was bad enough to foul my plugs wouldnt you think there would be oil on top of piston.
i really appreciate all the advise but I am throwing in the towel for a couple days. I have some concrete to get poured now the rain is over.
hopefully be back in action by norwalk!
