#21 |
I believe it oil. It doesn't smell much like gas. I am headed to pressure check some things. Let u know Results shortly.
#22 | |
Liked 10 Times in 7 Posts
#23 | |
If I knew the answer I wouldn't be on here. I am going to tear into the head I don't find nothing obvious I will have the pistons on the bench before I sleep I promise. |
#24 |
agree with the oil ring problem
Gary Burr IHRA MEMBER # 1958 Stk 1949 |
#25 | |
Liked 308 Times in 103 Posts
Mike Taylor 3601 |
#26 |
Liked 693 Times in 205 Posts
I had a broken expander on the oil ring and it pumped oil like crazy. Pull the piston and you will find the problem. Dyno
#27 |
Liked 880 Times in 311 Posts
Did you say Speed Pro/ Sealed Power rings?
If they are: Second ring installed upside down. Reverse twist is pushing oil up the cylinder. Second choice would be the oil ring expander overlapped. Have you rotated the firing order on the cap to be sure that there is one firing cycle that is dead? I had a HEI kick my butt like that!!
Adger Smith (Former SS) |
#28 |
What distributor do you have in it?
#29 |
Check valve springs on that cylinder.
#30 |
I have total seal rings. i have msd ignition I have changed every piece of it. I have done everything most has named twice. the piston is clean as a pin guys. there is no oil ,if a ring was bad enough to foul my plugs wouldnt you think there would be oil on top of piston.
i really appreciate all the advise but I am throwing in the towel for a couple days. I have some concrete to get poured now the rain is over. hopefully be back in action by norwalk! |
