Old 04-30-2014, 10:57 PM   #11
Kevin Panzino
Kevin Panzino's Avatar
Liked 759 Times in 139 Posts
Default Re: Improving 60' times, third gen f-body
Agree with most of what has been said.
And Yes, you Need way way way more gear, and more converter for sure.
Old 05-01-2014, 08:25 AM   #12
TonyB83
Thank you all for the replies.
the converter and gear sound like the makings of a street/strip car and not a bracket car. Tell us about the engine...heads, manifold, camshaft, compression, etc.
3rd gen f body bracket cars weighing 3100-3200 lbs. with driver run easy mid to low 10's with nothing special small blocks, power glides, 8" converters, 4.56 gear and 10" tires
Originally Posted by MAURICE BLENDHEIM View Post
Tony… What engine displacement, cam, intake, head and carburetor? Does the TH400 have stock rotating internals? What determined your choice on 3.73's. MB.
383ci, Comp XE288HR cam, Edelbrock RPM Air Gap, Holley 650 (modified, flows 740) AFR 195 heads (ported, 2.05 valves), 10.9:1 compression. Stock trans internals, just upgraded soft parts. Went with a 3.73 mostly because it's street driven but I wouldn't be opposed to going to a 4.10.
TonyB83 is offline   Reply With Quote
Old 05-01-2014, 10:03 AM   #13
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
so it is a street/strip car.
That said, it's all about compromises, what you are willing to sacrifice in drivability for quciker ET's but without question you need more converter and more gear and the right converter from the right manufacturer won't give up any street manners.
Old 05-01-2014, 01:28 PM   #14
njk53
I think the 3:73 gear and converter are the issue. I would think a converter in the 4800-5000 range and a 4:56 gear would do the trick. What RPM are you turning the motor through the lights? Depending on trap RPM you may be able to stand even more gear.
Nelson Kowal
Stock 345
Old 05-01-2014, 03:26 PM   #15
Greg Hill
Liked 279 Times in 68 Posts
1.44 with a 3.73 gear, stock 400 and a tight converter is pretty good. A low first gear trans (2.75) would help quite a bit, maybe a 200 or a 200r4 with overdrive since it's a street/strip car then you could use more rear end gear.
Greg Hill 4171 STK
Old 05-01-2014, 09:40 PM   #16
Doug Blackley
Doug Blackley's Avatar
Going to the 4.56 gear will allow a taller tire and help the launch a bunch. And the 56 gear isn't that bad to live with on 5he street either.
Doug Blackley 1697 STK
Old 05-01-2014, 11:07 PM   #17
MAURICE BLENDHEIM
Liked 285 Times in 87 Posts
Tony...4.10 - 4.56 -4.88's alone should put you into the low 1.40's maybe high 1.30's if your lucky. Faster by adding something like a 4000-5000 convertor, but you may sacrifice the street car thing? Your intake and cam will become a factor the closer you come to 7000 RPM. Hope this helps...MB.
MAURICE BLENDHEIM is offline   Reply With Quote
Old 05-02-2014, 08:32 AM   #18
TonyB83
Thanks again for all the replies.
Consistency is what I'm after here. While I'm not opposed to a gear and converter change, I'm more interested in suspension tuning at the moment. Do you guys think I'd benefit from either coilovers or adjustable shocks? I see a lot of guys on here who are running well with the Lakewood 90/10's and 50/50's but I also see a LOT of you who have gone to coilovers or adjustable shocks. What is the determining factor here? I'll admit, I can't justify the $1500 for the Santhuff stuff but I'm open to recommendations.
As a side note, I measured the angle of my LCA's last night. They are in the bottom hole of the lca bracket ( I know you guys hate them) and are at +5*. Moving them to the next higher hole looks like it would give them a negative angle and put the IC behind the car.
Old 05-02-2014, 09:01 AM   #19
njk53
I think your suspension set up seems to be good and going to high dollar adjustable shocks and coil overs will only get you marginal benefit. As stated by Doug try a 4:56 or similar gear with with a taller tire and see what happens.
Nelson Kowal
Stock 345
