Got a question about oil pressure. I noticed during my last run that when the car shifted into 2nd gear my oil pressure dropped to about 15-20 for approx. 1 second then went right back to 45- 50 for the remainder of the run and the return road. The motor is a super stock Ford 289. I use a canton pan and pick up. I double checked the pan to pick up clearance and seems to be ok. Any thoughts??????
Liked 348 Times in 152 Posts
Is it front sump or rear?
Also, HV pump or std. volume?
Phil Molski PMR Performance S/C 1623 |
Liked 20 Times in 9 Posts
Maybe the oil is shifting to the rear while the car is accelerating while the wheels are up ,and Wow you are really multitasking I can barely watch the fuel pressure gauge and its right in my face.
7015 E/SA Sooner Storm |
Mine does that when I get low on the oil level.
Don Higgins - Super Comp #360H |
Sorry, it is a front sump pan and a standard volume pump.
Liked 71 Times in 38 Posts
Is the sump open around the pick-up? A trap door/ baffle would help keep the oil at the pick-up.
Liked 279 Times in 68 Posts
Add another quart of oil.
Greg Hill 4171 STK |
