Old 06-17-2014, 01:53 PM   #21
Mike Schwartz
Liked 250 Times in 90 Posts
Default Re: Steel rod life expectancy
That's an interesting site. I used it to check who is importing nitromethane. (http://portexaminer.com/search.php?s...t=nitromethane) Schumacher Electric & VP Racing Fuels are there, but also a lot of names I don't recognize.
Old 06-17-2014, 02:25 PM   #22
SSDiv6
Yep. If you do a search, you would probably remember many years ago the war between Schumacher, NHRA and VP Fuels. As I remember, Schumacher was buying Nitromethane from China and selling it to other racers at a lower price than VP and probably also hurting the profits.
Old 06-17-2014, 04:09 PM   #23
cutta
cutta's Avatar
Liked 5 Times in 2 Posts
At the end of the day isn't this all a question of quality control? If the parts get back from China with same material quality and saves the consumer some cash, is that not a good thing? I know a lot of crap comes back here from over seas due to lack of quality control but if manley is ensuring it meets their particular quality standards, I don't see an issue.
Adriel Paradise, Paradise Racing Team
Driver/Crew Chief(at least my dad claims me to be)
B.S. Mechanical Engineering, University of Arkansas
cutta is offline   Reply With Quote
Old 06-17-2014, 07:41 PM   #24
SSDiv6
Ariel,
They only way a company can do so by creating a standard or specification for their products and having contract first article inspection oversight on location at the foundry or manufacturing facility.
Do a search on this forum on recent complaints as regards to the inconsistencies of their retainers.
Nevertheless, the Israeli company that makes the Titanium valves for Manley, is a reputable company that makes aerospace components.
Old 06-18-2014, 01:31 AM   #25
Bill Edgeworth
Ariel,
Third party audit/inspection and quality control companies are now a huge industry in China. You can get just about any ISO or ASTM test you want done there now. You can have tests done during and post production……whatever you want and even more commonly inspection of container loading to make sure you don’t get ripped off. Even Chinese companies use these services themselves now to make sure their sub-contractors don’t rip them off. There is a full spectrum of manufacturing there from absolute top level quality manufacturing to companies that can’t make anything but garbage. If you have something from China that junk it’s probably because the number one criteria of the guy selling it to you was getting it at the lowest possible price.
Interesting thing going on there now especially in Guangdong Province is that lots of big corporations are now moving out to places like Vietnam because they can make things even cheaper.
So based on you comments about quality and consistency they are probably less concerned about the quality than they are the price.
Bill Edgeworth 6471 STK
Bill Edgeworth is offline   Reply With Quote
Old 06-18-2014, 09:32 AM   #26
SSDiv6
Good explanation and I agree; just tried to give the Cliff note's version.
Old 06-18-2014, 09:50 AM   #27
Dion Hildebrandt
Dion Hildebrandt's Avatar
Originally Posted by joespanova View Post
In a situation like mine , where you lose an aluminum rod..........was it a bearing / oiling failure that caused the rod to fail...........or the rod getting kicked out of shape that made it "appear" to be a bearing failure? Hard to say.........the crank has bearing metal transfer that was obviously hot...........but why? Which came first ? Is the oil system adequate ?
Rods probably have 120ish runs on them.
Cut open the oil filter, it will give a better picture on what happened first. Had the same thing happen recently, and the filter was loaded with brass indicating a bearing failure.
Dion Hildebrandt 6009 STK H/SA
Dion Hildebrandt is offline   Reply With Quote
Old 06-18-2014, 10:17 AM   #28
joespanova
Liked 13 Times in 11 Posts
Good point. In aluminum rod combos where the rod has plenty of cycles you would tend to think its a rod failure , BUT , a bearing failure is certainly a possibility......... with the rod getting kicked / stretched out of shape that in itself may have caused the bearing failure.......chicken or egg?
Old 06-18-2014, 10:32 AM   #29
Ed Wright
Ed Wright's Avatar
Every aluminum rod failure I had pulled into in the middle. Big eng spun freely on the crank, with a good bearing inside. All big end failures I have seen were bearing failures. If it's black, it sure wasn't the rod.
When you set your bearing clearances, think about the expansion rates.
Ed Wright 4156 SS/JA
Old 06-18-2014, 10:41 AM   #30
joespanova
This rod had a clean break right in the middle of the beam...........but the bearing was also blackened and destroyed........along with the rest of the big end in the pan..............the pin end was perfect
