Old 06-20-2014, 05:11 PM   #1
joespanova
Liked 13 Times in 11 Posts
Default Crankshaft repair
Anyone have any suggestions .
I have 1 journal that may need repair , however , this journal is hard chromed , as they all are. Years ago I had Crankshaft Specialist in Memphis do some work after a rod break. They did very nice work ......then. From what I'm reading on line NOW , they / he is an untrustworthy ripoff. I am only repeating what you can see for yourself with a Google search.
So , what happened to them?
And who now is doing hard chrome repairs?
Old 06-20-2014, 06:28 PM   #2
Charlie Laraia
Default Re: Crankshaft repair
Joe,
You have a PM.
Charlie Laraia is offline   Reply With Quote
Old 06-20-2014, 06:48 PM   #3
voltdr
Liked 100 Times in 51 Posts
Mile High Crankshaft 303-781-6764
voltdr is offline   Reply With Quote
Old 06-20-2014, 06:52 PM   #4
SSDiv6
Liked 1,604 Times in 583 Posts
Shaft Tech in Fostoria, Ohio
www.shaftech.com
Old 06-20-2014, 10:08 PM   #5
joespanova
Thanks guys........
Old 06-21-2014, 04:17 PM   #6
carl hinkson
Liked 18 Times in 10 Posts
Dougy Rowe turned into a bad guy, Callies and Bullet cams offer crank repair as well.
carl hinkson is offline   Reply With Quote
Old 06-21-2014, 11:35 PM   #7
joespanova
They don't do chrome.......
Old 06-22-2014, 12:29 AM   #8
SSDiv6
Speak to Nick Boes at Shaftech.
He specializes in doing repairs that others can't.
Old 06-22-2014, 07:12 AM   #9
joespanova
Thanks
Old 06-22-2014, 11:49 AM   #10
Liked 1,880 Times in 422 Posts
It really is not necessary to chrome a crankshaft these days. Chroming was commonly done when it was much harder and more expensive to nitride a crankshaft, only big corporations had access to it. When you grind a crankshaft, especially if you have done a repair, once you grind it very much, you grind through the nitriding, and in some cases, the heat treating. You end up with a journal surface that is not real hard, it won't get quite as slick, and it will be more vulnerable to debris and sticking. You don't want the entire crankshaft hard all the way through, but you really need to get the surface hard. Chroming a crank merely makes the surface hard, and there is a risk of hydrogen embrittlement. These days, most good crankshaft repair businesses have access to both heat treating and nitriding.
