#11 | |
As I understand it we are not doing heads up races at these events. So I'm sure no one would mind if you showed up and just dial what you can run even if its over index. But Jim or Jim will have to comment on this as they set the rules.
Bill Edgeworth 6471 STK |
#12 |
Liked 240 Times in 112 Posts
Yes, it's over index.
Dave Noll, EF/S ,?/SA 6526 |
#13 |
Liked 4 Times in 2 Posts
No heads ups, unless it's the final an both racers agree on it, an you Atleast need to dial the index.. we do have scales
#14 |
Well it should be @ weight but I have to run it across a scale again. And it is too far off to dial the index. Man I hope them gears make a difference. Thanks for the input.
