Liked 99 Times in 60 Posts
Racers,
when using a 3 speed with brake which trans do you run? SBC, about 600 horse, 3100 pound car,
Larry Woodfin 471W |
Liked 9 Times in 3 Posts
pro-trans. give the guys at A-1 a call and they will set you up.
Mark Markow 171 ss/tb |
Liked 866 Times in 235 Posts
If it's a Bracket car , a more economical alternative to the Pro Trans would be a TH350 with a Coan trans brake valve body.
I've built many of these , and with the addition of the TH400 int sprag they are very durable. ....I have some Bracket racers who go 250 runs or more between freshen ups. Defiantly not as quick as the Pro Trans and no clean neutral, but way less expensive .
Tom,
SS GT/TB with 327, the 585 Holley combo. A $5,500.00 plus trans is not in my budget for the initial construction so most likely I will begin with a powerglide w/brake. [I have plenty of powerglide parts]
Liked 1,919 Times in 576 Posts
good choice using the powerglide to set up a new car. I am still using a powerglide in my car but am going to try a 350 turbo soon to see how the car likes it.
Mike Pearson 2485 SS |
The TH350 ,if the stock 2.48 first gear suits your combo, can be built with an aluminum drum ,TH 400 int sprag , trans brake valvebody for less than half the cost of the Pro Trans.
I would venture a guess that the performance advantage of the Pro Trans over the TH35 would be about .080-.120 second. depending on the ratios used.
#7 | |
Liked 284 Times in 87 Posts
I think Tom is right. a lo-buck th350 would be faster than the glide in your application.
Liked 99 Times in 21 Posts
I remember talking to Joe LoCicero years ago about his SS car and he sad "if I want to go fast I run a turbo, If I want to win rounds I run a glide" Don Jackson
In the 2000 - 2002 season I raced an IHRA Crate Motor stocker. The initial build up was with a 200 trans. In the fall of 2000 the 3 speed broke and I swapped in a powerglide to make an up-coming race.
The car was sooo much easier to stage [smoother, less harsh] and became dead-on consistent. With the powerglide I won more and was more relaxed when driving. Never reinstalled the 200 trans.
