Old 07-29-2014, 02:04 PM   #1
Rusty Davenport
Liked 101 Times in 27 Posts
Default Stocker roll cage bar beyond firewall rule......
I just ask the crew on the west coast about running the roll cage bars through the dash beyond the firewall and attaching to the frame. They said there was no safety advantage in doing that and NO to the idea in stock eliminator. The NO is ok with me as long as we are consistent but am I missing something on the safety advantage ??? Can I weld the mounting plate to the floor pan ???
NHRA AND IHRA STOCK ELIMINATOR 2772
Rusty Davenport is offline   Reply With Quote
Old 07-29-2014, 04:40 PM   #2
David Lee
Liked 346 Times in 126 Posts
Default Re: Stocker roll cage bar beyond firewall rule......
I wonder where he got his degree in mechanical engineering. .
Old 07-29-2014, 05:15 PM   #3
SSDiv6
Liked 1,572 Times in 580 Posts
What makes you think a mechanical engineer gave the response?
Old 07-29-2014, 05:17 PM   #4
SSDiv6
NHRA has never allowed any component that is part of the roll bar or roll cage to go past the firewall in Stock Eliminator.
Old 07-29-2014, 08:42 PM   #5
David Lee
I was try to state that he was very ignorant in his response. Any roll bat that would extend beyond the firewall would be helpful in a front end crash.
The statement was sacasm
Old 07-29-2014, 09:24 PM   #6
Karl Owens
now there are 8 second stock eliminators, shoudnt safety be #1 priority. What is NHRAs reasoning behind not allowing roll bars to tie the complete chassis together? Firewall flex and broken trans cases can be dangerous at high speeds. Look how long it took NHRA to allow aftermarket brakes in Stock which in my opinion any component that improves safety should never be an issue. The other issue I have problem with is steering, I think rack and pinion should be allowed in all classes, to replace antique steering on most cars beside newer ones.
NHRA Stock/Super Stock 1078
Karl Owens is offline   Reply With Quote
Old 07-29-2014, 09:25 PM   #7
David Lee
Thank you!
Old 07-30-2014, 08:02 AM   #8
Billy Nees
Liked 7,682 Times in 1,730 Posts
Ho Boy, here we go again!
And extending the cage is ONLY a safety issue. There's NO performance benefit at all to stiffening up the chassis or getting that heavy-*** old steering out of the front and replacing it with lite stuff.
Here's a novel idea, If you personally don't feel safe in your 8 second Stocker, then get a 12 second Stocker!
Billy Nees 1188 STK, SS
Old 07-30-2014, 08:24 AM   #9
Karl Owens
That means cars that came originally equipped with a steering rack have an advantage.
Old 07-30-2014, 08:28 AM   #10
Rusty Davenport
Does this even get looked for in tech ??? I find it hard to believe that the new stocker factory rockets are complying with this rule----- really ???
