I have a 71 nova with a 278 hp 350 the car wint rev past 5200 on the track but does in burn out. i changed fuel pump and reg thinking it would solve it i raced sat and it didnt it has a hy cam with lifters with shims in them i set the valve lash at 0. where should i look next
thank you |
Liked 308 Times in 103 Posts
have msd chip rev limiter take chip out,they will rev in water and shut off under load if bad.
Mike Taylor 3601 |
i don't have msd i have a hei only, the fuel pressure Gage never drops below 5 psi, do i need a msd?
Also disconnect tach.
Change the HEI cap and rotor also, any HEI will work your just testing to see if it runs fine, if it dose you can repair or replace yours then, but that take the whole dist. out loop completely. No you don't need a msd if it ran before it'll run again (I don't need no stinking msd). Last edited by bigfoot584; 07-30-2014 at 10:06 PM. |
thankx i will
Had a similer problem,would only go 5000 in 1st gear,ok in 2nd and 3rd.changed pump,regulator,filter,cap,rotor and unhooked the tach(not all at once lol) changed the hei control module and it works perfect
Liked 13 Times in 10 Posts
try 7 lbs. fuel pressure
Guest
Posts: n/a
Need to look at that HEI module. I had one in a car I was trying to sell. It ran me through the ringer. I bought and tried 3 different modules before I bought an MSD replacement, and that fixed it. If you know somebody with a distributor machine you might want to take it there and have it checked out for yourself. I've heard GM had different part numbers for modules, and the ones that came in the HP cars were the ones to use.
Liked 584 Times in 94 Posts
Todd's right. You can actually have it tested at your local Auto Zone store. That's if you're lucky enough to find someone there that knows how to do it. But, "they do" have the machine.
Make sure your secondaries are opening too. Don't ask me how I know about that. Hahaha
Family Tradition Racing |
