Old 09-09-2014, 10:09 AM   #21
art leong
Default Re: EMI / RFI and setting timing = problems
You remarked about everything being grounded etc. If you ground the shielded cable pickup wires, you just created a magnetic for EMI problems.
I did this, so I learned from experience.
Art Leong 2095 SS
Old 09-09-2014, 10:37 AM   #22
buzzinhalfdozen
Liked 11 Times in 8 Posts
Art, you are correct any shield should only be grounded on one end, by grounding both ends you're making an antenna.
Joe Buchanan SS/BX 3117
Old 09-09-2014, 11:15 AM   #23
joespanova
Liked 13 Times in 11 Posts
OK
So what the heck is the ground for?
Old 09-09-2014, 11:17 AM   #24
joespanova
Originally Posted by buzzinhalfdozen View Post
btw you actually will only have 1 lite that works on your race car!
True LOL
Old 09-10-2014, 08:05 AM   #25
buzzinhalfdozen
Joe the ground is for the shield, it should only be connected at 1 end to ground.
Old 09-10-2014, 08:32 AM   #26
joespanova
I dont follow..there's one pigtail.........how could you connect it at both ends?
Old 09-10-2014, 09:59 AM   #27
buzzinhalfdozen
Art had commented about grounding shields, yes this harness has only 1 lug end but others have exposed wires or cable that some people connect to ground. By connecting both ends of a shield to ground you can actually induce EMI issues. If you have connected the lug on that cable to ground then that is correct. Most older MSD systems would work perfectly with an unshielded crank trigger jumper or pickup when they introduced the digital systems unshielded wiring caused lots of problems.As I stated earlier, the switch from analog to digital systems opened up a lot of issues for quite a few racers.
Old 09-10-2014, 11:44 AM   #28
joespanova
Yeah . Me being one of them
Old 09-10-2014, 12:10 PM   #29
Bill Edgeworth
Just something everyone should know about timing lights;
The inductive pick up in most utilize ferrite. This is a magnetic ceramic material used to make the nest that the wire fits in in the pick up.
Ferrite is a very fragile material and if it cracks the performance of the pick up will be compromised.
better timing lights usually have the core encapsulated to help prevent this but I have a $400 Snap-On one that I once cracked the core trying to fit it on some real fat wires.
So what you think is noise could be a timing light problem.
Bill Edgeworth 6471 STK
Bill Edgeworth is offline   Reply With Quote
