Old 09-12-2014, 02:34 PM   #11
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Default Re: Metric 200 Flex and Trans shield
Originally Posted by John Nechiporchik View Post
I just reviewed the rulebook ....again.
In the Stock section, there is no reference to a shield for trans or flexplate.
In general regs. section 2.14 it says that a trans shield (SFI 4.1) required in 10.99 or quicker. A SFI 29.1 flexplate and SFI 30.1 flexplate shield is required for 9.99 or quicker.
I hope I got this right!!
Just a quick heads up on the NHRA rulebook.....
It is written in NHRA speak which means that it is encrypted in a code that only NHRA has the key to....
The next time you want to read and attempt to decode the rule book you have to start with a well-lighted area, a large cup of coffee (strike that) a large bourbon & seven and have at it....
Understanding and making sense of the NHRA takes years of practice..
Just ask any Stock or Super Stock racer..
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 09-13-2014, 02:34 PM   #12
SuperStock 1890
SuperStock 1890's Avatar
I have the Waters set up. Not too fun to install.
You don't know what you don't know yet.
SuperStock 1890 is offline   Reply With Quote
Old 09-13-2014, 03:32 PM   #13
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
If you go to any NHRA track and run the car on a regular bracket day or a test and tune day......A track official can and may tell you a trans shield is required on a 10 second car.
The rulebook has always had issues in there like this.
A Stocker did not need a fire jacket when a bracket car did in the past.
Now Stockers need jackets and pants so it's not an issue anymore.
A Stocker may not need a trans shield at an NHRA race where Stock is run but it does if it is a 10 second car at a regular bracket or T&T day...
I never had one but did see one is made for a Metric......
Rich Biebel
S/C 1479
Stock 147R
Old 09-13-2014, 04:25 PM   #14
Tony Goodman
Liked 18 Times in 4 Posts
I run a shield on my stocker because I bracket race it also. In bracket racing 10.99 and quicker require one, so I run one.
Tony Goodman is offline   Reply With Quote
Old 09-13-2014, 11:08 PM   #15
John Nechiporchik
Liked 13 Times in 7 Posts
Looks like McClay sells the Waters unit.
Based on the responses, I will use an SFI flexplate because I have one......will not attempt to install/fit a flexplate shield as it is not required.....and will likely install a trans shield for next year as I will probably bracket race as well as run NHRA/IHRA.
Thanks for all of your input.
John Nechiporchik is offline   Reply With Quote
