Old 09-28-2014, 10:06 PM   #1
FED 387
Liked 335 Times in 182 Posts
Question mustang lx ????
what was the last year that the Mustang LX 5.0 engine had a carb ??? or were they always injected??
Old 09-28-2014, 10:14 PM   #2
rawhide
Liked 7 Times in 5 Posts
Default Re: mustang lx ????
1985 to the best of my knowledge.
Roland
rawhide is offline   Reply With Quote
Old 09-28-2014, 10:26 PM   #3
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
85 and was a stick only with the 5.0 also first year of the hydraulic roller cam.
86 was the first year of the FI 5.0
Sean
Sean Marconette
84 Mustang
5060 SS/N
Sean Marconette is online now   Reply With Quote
Old 09-29-2014, 12:40 AM   #4
Rory McNeil
Liked 1,112 Times in 304 Posts
Although the 5.0 Mustang first had multiport EFI in 86, 5.0 Mustangs with automatics came with a throttle body EFI called Central Fuel Injection in 84 and 85, while the 82 thru 85 5.0 Mustangs with carbs were stick only. 82s were 2 barrel, 83-85s had a Holley/Motorcraft 4 barrel. In 1979, you could get a Mustang with a regular 302 2 barrel, with either an automatic or stick. No 302s in 80 or 81, the only V8 was an oddball 255. By the way, the 79-86 Mercury Capri was a "sister" car, and used the same powertrains, albeit with no SVO equivilent.
NHRA 6390 STK
M/S 85 Mustang
Old 09-29-2014, 09:24 AM   #5
FED 387
Thnx guys
Old 09-29-2014, 04:44 PM   #6
Freddie
Freddie's Avatar
Liked 3 Times in 2 Posts
interesting info, I have an 85 I have been wanting to do something with. I would only need to make a few changes to its current setup.
One question as I did not see it in the rule book anywhere. Do the pedals need to be stock as well? I have an aftermarket throttle pedal (mounts to the roll bar under the dash).
NHRA: Comp 2200 - S/C 2201
NMRA 2012 Outlaw 10.5 #10
Freddie is offline   Reply With Quote
