Old 10-16-2014, 09:12 PM   #11
mcashman
Liked 6 Times in 3 Posts
Default Re: Launch rpm for F/S. 396 ,325hp ?
Update I lowered caltrac bar to lower hole no pre load, switched to 90-10 on fronts and lowered launch to 4200 then 4400 went 1.72 then 1.66 60 foots. Both dead hooked.not fast but much better. I will figure out what clutch stuff I got. Thanks for info.
mcashman is offline   Reply With Quote
Old 10-16-2014, 09:58 PM   #12
69Cobra
Liked 2 Times in 2 Posts
IMO If you've got it dead hooking keep raising the launch RPM's until you get about 1 full revolution of the tire. Then tire making adjustments to the clutch, chassis, tires, shocks etc... to get it to dead hook again at your new launch RPM once you get that then keep raising the launch RPM again until you get your 1 revolution back. Obviously the time slip (60') will be your guide. Just my .02
Kris Rachford
69 Cobra 428CJ 4 Speed
C/S 3032
Old 10-17-2014, 12:59 PM   #13
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
Mike Taylor 3601
Old 10-17-2014, 01:46 PM   #14
Rory McNeil
If he is still running radial slicks, it will be very difficult to get only 1 revolution of the slicks. I have used both the M/T 9x29.5 3056STs, as well as the Hoosier 9x29 D07s, both worked great, although the M/Ts seem to not "go away" as severely when they reach the end of their life. On my car, when fresh, the Hoosiers are a tick better on 60foots.
NHRA 6390 STK
M/S 85 Mustang
Old 10-17-2014, 09:16 PM   #15
69Cobra
My experiences have been the same as yours Roy and yes I don't know if he's going to have any luck with the radial I've never tried them myself.
Kris Rachford
C/S 3032
Old 10-17-2014, 10:11 PM   #16
Doug Domm
Liked 84 Times in 21 Posts
Ok, the 3056st is a stick tire but what effect would that tire have with an automatic car?
What is the build difference of the 3056st to the 3056? Is it just compound or constructed different as well?
Doug Domm is offline   Reply With Quote
Old 10-17-2014, 10:28 PM   #17
Rory McNeil
The sidewalls, although not really a stiff sidewall, are stiffer than a normal slick. I also believe that the tread compound is a bit harder.
NHRA 6390 STK
M/S 85 Mustang
Old 10-17-2014, 10:45 PM   #18
Doug Domm
That is what I have understood as well. That being said, if you have an automatic car that hooks with the st tire would the stiffer sidewall help with reaction and performance? Will the st still grow as much as the non st?
Old 10-18-2014, 08:13 PM   #19
mcashman
Next time will be in 2 weeks I will defiantly try to get the 1 revolution and see how it pays off. I have rear shocks set second softest setting I was thinking of stiffing them think it would help 60 ft times?
Old 10-19-2014, 06:45 AM   #20
james schaechter
We have been testing off an on with a clutch set up that we can run radials. In the right conditions it can be good. The cool track and whatever led you to dead hook can be reason it works now. If you race on normal summer conditions be prepared for disappointment if you think it will work when the track gets hot or you just have too much hit to hold it. It is a very very fine line. When the radials start to spin you can go from a 1.40 60 foot to 1.70. 😁
I think that radials can be faster someday. I have gone 10.70's in E stick with them. But I don't have a big enough tuning window with them to leave them on all the time. Too easy to roast them on the line for me anyway.
Let us know how it goes and take video if you can.
James Schaechter 3163 STK
