#31 | |
Liked 99 Times in 49 Posts
#32 | |
Liked 140 Times in 46 Posts
#33 |
Liked 20 Times in 9 Posts
You must be planning on some really high numbered gear ratio to get that monster thur end,with a 30 tire.And i'll be waiting to see and hear this one.
7015 E/SA Sooner Storm |
#34 | |
Liked 9 Times in 8 Posts
#35 |
Liked 2 Times in 2 Posts
When and where is this car going to make its debut?
Kris Rachford 69 Cobra 428CJ 4 Speed C/S 3032 |
#36 |
Liked 112 Times in 31 Posts
Lou,
Yes there are specs for all that. NHRA tech has them and uses them to certify pistons for the accepted list. Although they don't give cc volumes for all flat-top pistons with notches, they do for all the flat-top Clevelands. The Chevy pistons are hit and miss, but if you want to look at the blueprint specs for the 1970 Chevy engines, you'll see lots of volumes for flat-tops. Bill's engine has domes so no valve relief spec would be given, but they have it at NHRA. Whether they'd want to enforce it as a minimum spec for compression or a maximum spec for cam fitment would be up to them. Maybe I should ask NHRA as we run an original Boss 351 Mustang (so you're wrong again Bill as I mentioned our car on one of your first threads). We don't race it MUCH or HARD, because it has the original #'s matching block in it but yeah, you would be hurting our combo. Jon, Yep, that's the car. I helped work on it a couple of times when it was up in this area. As far as I know, the replacement version was sold to someone on the East Coast but hasn't been raced since sold. Jerry Jerry |
#37 |
My pistons are on the list, but I am having a new set made with some improvements done to them, As far as I am concerned, I can read the book and that is all that matters.. not what somebody "thinks" it says
Jerry, with all due respect and I do admire an all original car, if you are not going to run it hard, you might as well stick to car shows and don't tell me what I can and can't do with mine. Kris, the car has been sitting in my shop stripped to the bone for several months while I debate which direction I am going with it, most likely its getting the 25.5 treatment so when I get tossed out I will just step it up. Last edited by Bill Diehl; 10-30-2014 at 12:43 AM. |
#38 |
Liked 240 Times in 112 Posts
Good luck Bill. Go get em.
Dave Noll, EF/S ,?/SA 6526 |
#39 |
Jerry,
I was on the starting line that morning when it happened. Nasty is all I can say! I always wondered what happened to the replacement. |
#40 |
Liked 8,124 Times in 1,534 Posts
Mr. Diehl, I believe you are mistaken. Tomorrow is Halloween. Aprils Fools Day was several months ago. Regards, M.J.
