Old 10-30-2014, 06:44 PM   #41
JRyan
Liked 112 Times in 31 Posts
Default Re: 600 hp small block stocker
Jon,
But he did win the $50 bet for best wheelie.
Jerry
Old 10-30-2014, 07:09 PM   #42
Bill Diehl
Bill Diehl's Avatar
Liked 9 Times in 8 Posts
Mr. Diehl, I believe you are mistaken. Tomorrow is Halloween. Aprils Fools Day was several months ago. Regards, M.J.
Thanks for pointing that out for me....now I am all confused
Since I got my days confused I was going to post up some eye "candy "for ya all to chew on and enjoy, but decided against it, don't want to hurt no more feelings
Bill Diehl is offline   Reply With Quote
Old 10-30-2014, 08:37 PM   #43
astikhossw
astikhossw's Avatar
Liked 20 Times in 9 Posts
Talking Re: 600 hp small block stocker
Hey Bill what about a taste of that candy for the good kids.after all tomorrow Halloween.
7015 E/SA Sooner Storm
astikhossw is offline   Reply With Quote
Old 10-31-2014, 07:03 AM   #44
rod butcher
Liked 132 Times in 27 Posts
For a cleveland to make 600 in stock eliminator trim it needs to make 1.70 hp per cubic inch. A real good 396/375hp BBC makes about 1.62 hp per/ci and that is the same head basically. I don't see it but then again I was told by a few people that they had a 305/263 that made 460. The race track doesn't lie, dyno's can be fooled or can be very liberal.
rod
rod butcher is offline   Reply With Quote
Old 10-31-2014, 07:48 AM   #45
Bill Diehl
Bill Diehl's Avatar
rod
This is true, and why it needs a good car.....but some things to ponder.......you can not get the "tech" on an .842 lifter like you can on an .875 nor can you get the shaft diameter as large as you can on the ford which means the valvetrain will not function as good at extreme speeds. The ford has almost a point more compression and a much better combustion chamber to work with. The rotating weight on the ford is almost 200 grams lighter. The intake manifold on both engines is worthless, let me rephrase that...the collectors think they are made from solid gold but to create horsepower, they leave a lot to be desired. the lifter angles, locations and spread are clearly better on the chevy, but.....
The question I have are those really good 396/375's running the .875 program? It has been developed over the years to function almost perfectly at 9000+ for 4 hrs at a time
Old 10-31-2014, 08:50 AM   #46
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Latest CarCraft shows Calvert's engine on the dyno at 963hp.
Old 11-01-2014, 10:42 AM   #47
goinbroke2
Liked 404 Times in 158 Posts
Any car mag could say 400hp or 1500hp and both would be just as believable....
Not bashing mags..oh wait, yes I am, but adding the cam that is their number one advertiser won't "add 150hp" with no other changes.
Maybe put a stock cam in a pro stock, dyno it, then put the pro stock cam back in...but other than that they're full of poo.
goinbroke2 is online now   Reply With Quote
Old 11-01-2014, 10:42 AM   #48
Rob Petrie E395
Liked 216 Times in 77 Posts
Originally Posted by Bill Diehl View Post
My pistons are on the list, but I am having a new set made with some improvements done to them.
I thought in stock the pistons had to be left alone and as they come from the manufacturer and be on the approved piston list. I am new to this stock eliminator stuff. So forgive me if I missed a rule change or something.
Old 11-01-2014, 10:55 AM   #49
SSDiv6
You are allowed to resubmit a piston for approval, or have a piston made with a different weight as long it meets the NHRA assembly weight requirements.
Old 11-01-2014, 11:16 AM   #50
Rob Petrie E395
OK I am with you know. The way I read it I thought I missed something in the rule changes that just came out. I did not realize that he was making new pistons to be approved.
Thanks
Rob
