#31 | |
The GMPP 401 aluminum head is listed as an NHRA accepted replacement part for the early cast iron big block Chevy closed chamber rectangle port head. There is a HP penalty for using the aluminum replacement head. For example, we used them on a 69 Camaro 427/425, and that raised the HP rating from 425 to 435, so we had to add 80 pounds when running them in A/SA. There are certain parts allowed by NHRA as replacements for old castings that are both difficult to find, and expensive to buy. In the case of cylinder heads, a HP penalty is applied, it usually starts at 10HP. In the case of the 401 head, it is not allowing a different engine combination, it is allowing the 401 head to be used as a replacement for the OE head, with a HP penalty applied. The same applies to some heads for other makes. An aluminum replacement head is allowed for certain combinations, and it carries a HP penalty.
Alan Roehrich 212A G/S |
#32 |
Liked 56 Times in 31 Posts
Thank you for the clarification.
Thomas NHRA 1959 D/SA |
#33 |
Liked 10,769 Times in 2,238 Posts
Ken you have a very good car, but a 70 Nova should be 402/ 395 iron, or 402/ 405 aluminum.
#34 |
Liked 18 Times in 8 Posts
#35 |
#36 |
Liked 652 Times in 184 Posts
Definatley some very fast 396's out there!!
I think A/S will be cool this year too! Hopefully with the new cars in there own classes it should bring back some old school cars. .
5664 GHI/SA 1985 CAMARO RED H/SA 1985 CAMARO BLUE I/SA |
#37 |
Liked 10 Times in 1 Post
I went 9.95 in Dan Fletchers car with that combo in the semis in Pomona a few years ago. Unfortunately it was heads up and Jimmy DeFrank went 9.74. It was a 375 h.p. rating at the time but I'm sure Jimmy can still go 9's .
Billy Leber 1150 SS, 1050 SG, 1962 STK, 185 SC |
#38 |
I think Jimmy, Joe, and Lance can all go 9's in B/SA.
#39 |
Liked 13 Times in 2 Posts
well if the cars are built with NHRA specs, I would be surprised any of them could
#40 |
Liked 30 Times in 17 Posts
