Old 10-14-2014, 11:19 PM   #51
B Aceves
B Aceves's Avatar
Liked 7 Times in 4 Posts
Default Re: Dan Fletcher Super Stock Videos - Opinions
Try removing the driveline and grease the splines on the yoke and make a hit .
Bob Aceves,
746 E/SA
A&M motorsports
B Aceves is offline   Reply With Quote
Old 11-24-2014, 12:27 AM   #52
Pat Cook
Did this problem get solved?
67 Ford Fairlane
F/SA
749
Pat Cook is offline   Reply With Quote
Old 11-24-2014, 06:07 AM   #53
65hardtop
I was told if you shut the car off and coast at the end of the run there is a lot of parts in the trans that arn't getting oiled since the the pump isn't being turned.
65hardtop is offline   Reply With Quote
Old 11-24-2014, 09:54 AM   #54
rod butcher
Liked 132 Times in 27 Posts
Dan,
If the bad heim doesn't fix it check the axles for runout. I had a drivers side axle bent that caused a bad vibration in the Mustang. Changed alot of stuff before I found it. Chucked both axles up in a lathe and could see it before I put the dial indicator on it. Good luck.
rod
rod butcher is offline   Reply With Quote
Old 11-24-2014, 12:03 PM   #55
doglover44
doglover44's Avatar
Liked 489 Times in 227 Posts
Hope you found the problem Dan and got it resolved by the way hows the new COPO Camaro doin ?
Jake Biermann
