For the Mustang 5.0 stocker - If I installed the bolt-in anti roll bar do I have to ditch the eibach drag launch rear springs and go to the same left and right spring rates? I let all the air out of the air bag and scaled the car and have even weight on both rear tires at full race weight. Oh yea and I ditched the rear factory sway bar also.
I would contact Team Z out of Taylor, MI. They are the Fox Body guru's.
Liked 33 Times in 16 Posts
Can't say what's what yet as the car hasn't been to the track yet. Using Team Z uppers, Southside lowers and stock GT springs...I elected to leave the factory sway bar on for the first attempt.
Rich Taylor I/SA - 321 |
Liked 6 Times in 2 Posts
To the Original Poster:
When using an Anti Roll bar, The spring rates should be even. The ARB is now controlling Body Roll, Not the Springs I would suggest not using the South Side and The Team Z uppers together. Both of those bars are trying to accomplish the same goal, changing the suspension geometry. I would use one or the other. The Team Z bars are what I use in my car. I have an NMRA Coyote Stock car that makes 450rwhp and weighed 2700lbs and went a 1.29 60 with Team Z products. |
#5 | |
Now I don't have to be the bad guy again. IC ..too high and too far back, besides being way over kill for O/SA
#6 | |
But will it work? I can easily swap lowers if need be. I also know the car won't be near as light as Mike's and nowhere near the hp.
#7 | |
Probably would work with just a lot of ballast and an air bag as well. At least you're supporting the aftermarket this way. ;-)
#9 | |
Liked 1,602 Times in 583 Posts
