#51 |
Liked 10 Times in 6 Posts
Doug, maybe you should put a stick in your car, because they never came with a automatic transmission from the factory. Tom
Tom Moock 5704 STK |
#52 |
Liked 53 Times in 16 Posts
Just for the record....the motor torn down at the Indy Nationals was a 1969 375/396 in a 1969 Camaro(not a 1970 402). Everything was found to be legal except for the piston weight, which was 28 grams light. At the end of that season NHRA changed the rule to a piston/rod assembly weight, which would have made the aforementioned engine legal.
#53 | |
Liked 1,909 Times in 427 Posts
Keith, Thank you for clearing that up, I thought I was losing my mind. Well, I already lost my mind, otherwise I wouldn't be fooling with all of this, I guess I thought I lost my memory. I remember you and I talked about this for an hour or so at Columbus a short time after it happened, and what was posted before you cleared it all up was not what I remembered. If memory serves correct, Schroeder bought that car as a running race car, the engine was not a Wikle, and all you did was put rings and bearings in it. At least that's what I remember, but then, I still don't trust my memory.
Alan Roehrich 212A G/S |
#54 | |
Liked 30 Times in 17 Posts
TP |
#55 |
I apologize for getting reeled in on the derailment of this thread.
There are a few Camaros out there and your gold '67 has to be one of my favorites. Tim, could you post a pic for us? I especially liked it with the beadlocks. TP |
#56 |
Liked 9 Times in 4 Posts
Tim has some pics of the 67 Gold Camaro under Class racer builds.
Tostoracing Retired S/ST and Stock owner/Driver Div. 5 Tech certification team |
#57 | |
Liked 662 Times in 187 Posts
Thanks Tracy The next time you see it it should look even better than it did and beadlocks are a must lol! I'll take the extra weight for the look unless this thing goes 10.000000 then they might get taken off ![]()
5664 GHI/SA 1985 CAMARO RED H/SA 1985 CAMARO BLUE I/SA Last edited by TOSTO RACING; 11-25-2014 at 02:19 PM. |
#58 | |
5664 GHI/SA 1985 CAMARO RED H/SA 1985 CAMARO BLUE I/SA |
#59 |
Liked 4 Times in 2 Posts
I have a Wikle engine and it passed teardown last year at the Fall race at Indy when I set the record.
M.Lind D/SA 801 |
#60 |
Liked 99 Times in 49 Posts
