Old 12-03-2014, 02:43 PM   #11
magnumv8
Default Re: steel or aluminum driveshaft?
Mark...go to the Mark Williams website and look up "critical speed"..... while a performance improvement is nice you need to spec out your driveshaft based on your trap rpm you achieve.....the diameter and material type will be decided once you have your shaft length and trap rpm....
as an example for my stocker build I needed a shaft 54" long and needed to handle at least 7000 rpm and since it had to be steel I required a 3.5" chromoly shaft.....while aluminum can give you a higher critical speed it is less durable.....
D L Rambo.....Stk 1300
magnumv8 is offline   Reply With Quote
Old 12-03-2014, 03:09 PM   #12
Bill Diehl
Bill Diehl's Avatar
Liked 9 Times in 8 Posts
Originally Posted by Jim Caughlin View Post
Same issue with lightweight rearend parts, gundrilled axles, alum spool, lightened ring gear, no noticable improvement. On the other hand, lighter weight flywheel and clutch made a huge difference. In my case, this is a 4 cyl motor that crosses the finish line at 9200.
If any gains are to be had you should see it by using all the parts.
You have met the required parameters.... rpm, 4cyl power, ect. all those "should" improve your performance, results speak louder than theory though
Bill Diehl is offline   Reply With Quote
Old 12-04-2014, 07:35 PM   #13
randy wilson
Liked 22 Times in 22 Posts
Carbo fiber. Don't know about improvements in performance, but takes the shock out of the driveline, and is way safer. Ran a 6.20 rear gear for over 100 passes at 3040# with a 5 speed.
don,t have one
Old 12-04-2014, 08:44 PM   #14
Jim Caughlin
Liked 808 Times in 247 Posts
I agree that carbon fiber is probably better but not legal in SS.
Jim Caughlin is online now   Reply With Quote
Old 12-05-2014, 11:01 AM   #15
Nathan Stinson
Nathan Stinson's Avatar
Liked 4 Times in 1 Post
I see a few comments about durability concerns with aluminum. Maybe I have been lucky but I have ran a Dynatec aluminum shaft for several season in my car. 3350lbs run 1.11 60' and have not had any issues at all. I do agree that the performance gains were minimal at best compared to a chromemoly shaft.
Nathan Stinson is offline   Reply With Quote
Old 12-07-2014, 09:16 PM   #16
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Swapped the stock 3" driveshaft in my 3880 lb. Chevelle back in '99 for a 3 1/2" MMC driveshaft from Denny's, worth .04 in the 1/4. Put thousands of passes on that driveshaft without issue or failure and it's still in the car today. Ran a best of 1.28 60 foot with it and well into the 9's.
Further, my 3144 lb. MPR Firebird has a 4" aluminum driveshaft and has been 1,17 60 foot and well into the 8's also without issue or failure.
Old 12-08-2014, 01:15 PM   #17
Jim Kaekel
Liked 541 Times in 112 Posts
I really think it depends on the application. I swapped a steel for an aluminum driveshaft at the track for a back-to-back comparison and gained absolutely nothing. The added bummer was that they were checking driveshafts at that very race. They wound up banning them at the end of that year in Stock Eliminator, unless they were OEM for the particular car.
Jim Kaekel 3836 STK
Old 12-08-2014, 06:18 PM   #18
Mickey Whaley
plastic
Mickey Whaley is offline   Reply With Quote
Old 12-08-2014, 06:57 PM   #19
Ed Wright
Ed Wright's Avatar
I changed from a Strange light weight steel spool to aluminum, lightened ring gear, and aluminum driveshaft. My car is evidently dumb, because I saw zero. Well, actually, I lost first round at the last race I ran at Memphis when it cleaned the right side splines out of the spool on the starting line. About got the tree.
Still have the driveshaft. Steel spool stays in it now, and I don't spend money on lightened ring gears.
Ed Wright 4156 SS/JA
Old 12-08-2014, 07:13 PM   #20
SSDiv6
I was told a story about Kip Martin (RIP) and his Super Stock Mustang.
Kip ran an Aluminum drive shaft which broke at a race.
I was told he found a steel replacement and his car slowed down a few 10th's and MPH.
As soon as he replaced the steel unit with an Aluminum one, he gained back his ET and MPH.
Also, as I understand, Stephen Johnson replaced his steel unit with Aluminum and also picked up ET and MPH on his Fairline.
