Old 12-05-2014, 08:35 PM   #11
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: Which is it......battery or ballast ???
Originally Posted by FED 387 View Post
Unless the rules have changed better check on this tho " if you are not running a fuel cell but still are using a "stock" gas tank you can use a gas tank shield located between the top of the tank and the trunk floor as an approved safety device-it is not considered disguised ballast!! Now don't go putting a 1 inch piece of plate steel but you can use either steel or aluminum plate to do this "thin" gauge like 1/4-3/8 inch depending on how much weight you need ---FED 387
According to General Section 4.3 the max for steel plate flooring used as ballast is 18 gauge. 3/64 of an inch max.
Dale
Old 12-06-2014, 10:32 AM   #12
FED 387
Liked 333 Times in 180 Posts
then it has changed--- how about a spare tire OR you can use heavier cross members too----are you trying to make the additional weight "easily removable" or are you just trying to add additional weight to the car----FED 387
