Old 12-04-2014, 09:23 PM   #1
Mark Faul
Liked 43 Times in 9 Posts
Default 40k hitch
Where would a guy purchase one of the 40,000 pound hitches commonly found on the back of truck conversion motorhomes?
Thanks
Mark Faul is offline   Reply With Quote
Old 12-04-2014, 10:16 PM   #2
FED 387
Liked 333 Times in 180 Posts
Default Re: 40k hitch
Cequent Products, Plymouth Michigan--- they own all the major hitch companies--- tell em what you are looking for and et them recommend something that will fit your needs---FED 387
Old 12-09-2014, 05:47 PM   #3
Mark Faul
I tried them. No luck. Also called NRC, and they could sell me the one they use for $1170!
I think I'll try getting mine beefed up some more locally.
Thanks for the recommendation.
Old 12-15-2014, 10:39 AM   #4
SSDiv6
Mark,
Call Torklift at their main office in Sumner which is close to you.
They already make a 30K hitch and may be able to help you.
http://www.torklift.com/index.php/pr...tch-magnum-30k
Torklift International
1901 Fryar Ave
Sumner, WA
253-261-5586
Old 12-15-2014, 07:39 PM   #5
Mark Faul
Thanks Joe.
Since they are close, it might be wise to just drive the mh to them and see what they think. They could probably fix or reinforce what I already have.
I have a piece of 1/8" steel plate running vertically with the 2" receiver tube through it. There's a 1/2" plate behind the tube horizontally and a box tube approx 1"x2.5" running at an angle to the old end plate of the semi. Then another vertical 1/8" plate vertical from that.
I think it needs some more metal and some triangulation? Hard to describe, but pulling a 3 car stacker it doesn't seem like enough.
Old 12-16-2014, 01:05 AM   #6
Geerhead55
Liked 5 Times in 5 Posts
Wink Re: 40k hitch
Mark,, you might also want to try Ballews' on M St. between So.Tacoma Way and Center St. I had them do some reinforcing on my MH this past summer and was pleased with the results. I'm not pulling a 3 car stacker like you,, but I'm thinking they can handle it.
Good luck whichever way you go.
Danny Durham
