Old 12-16-2014, 02:01 PM   #1
astikhossw
astikhossw's Avatar
Liked 20 Times in 9 Posts
Default Torque wrench
Where do you guys get the torque wrench that measure down to 5 inch pounds to set pinion pre load.I have been looking online and have not found one will go that low.
7015 E/SA Sooner Storm
astikhossw is offline   Reply With Quote
Old 12-16-2014, 03:16 PM   #2
Rob Petrie E395
Liked 216 Times in 77 Posts
Default Re: Torque wrench
I will look and check for sure when I get back to the shop. But I think mine is a KD 2955. Its 1/4 inch drive. So I welded a old 1/4 socket to a socket I use when checking preload. That way I don't have to use several adapters to get there. I dont remember where I got mine as I have had it for 15-20 years but they are available online through many places.
Hope this helps
Rob
Old 12-16-2014, 03:42 PM   #3
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Get a dial type or a beam type rather than a clicker. You can't get it right with a clicker.
http://www.modernbike.com/product-21...FW4V7AodpF4A-Q
http://www.craftsman.com/search=inch...orque%20wrench
http://shop.advanceautoparts.com/p/k...955/22988238-P
Old 12-16-2014, 03:50 PM   #4
astikhossw
astikhossw's Avatar
Ok thanks I was looking for the clicker type,So the dail or beam types or better for checking pinion preload.
Old 12-16-2014, 03:59 PM   #5
tj310
Snap on gte12a dial type ,I've had it a long time pretty well all its used for ...Trevor
Old 12-16-2014, 04:26 PM   #6
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
You'll need the dial type because you have to keep it rotating to get an accurate reading of the pinion preload.
Paul Precht is online now   Reply With Quote
Old 12-16-2014, 04:31 PM   #7
Dwight Southerland
Yes. Breakaway torque is much higher than the resistance torque.
Old 12-17-2014, 04:15 AM   #8
Adger Smith
Liked 880 Times in 311 Posts
Dial is what you need or digital. Most digital's have a memory so you can see the highest Tq and watch the rotational TQ as you turn it. I love my digital since I have changed over. I found you can over pull with a click. At least I had a couple of employees that did as Std Operational Procedure. You can't fool the digital. It tells you exactly what kind of pull you made. The Digital for the Tq to yield are even smarter!
Adger Smith (Former SS)
Old 12-17-2014, 09:04 AM   #9
Eman
Liked 133 Times in 76 Posts
I use a beam type, I think mine is a Mac. It works great, stays accurate and measures in both directions. Mine is 3/8ths drive so I use a 3/8 to 1/2 adapter.
