Old 12-23-2014, 09:29 AM   #11
Portatree Timing Systems
Portatree Timing Systems's Avatar
Default Re: Reaction time difference, bias ply vs. radial slick
Here is a bit of information on what effects rollout/reaction time. Weight is a huge factor. Front tire size is also important.
http://www.portatree.com/page--Tech-Tips--TechTip1.html
Happy Holidays!
www.portatree.com
Portatree Timing Systems is offline   Reply With Quote
Old 12-23-2014, 10:23 AM   #12
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,377 Times in 502 Posts
I am excited about Mickey Thompson's new line of smaller radials so I am really anxious to see how much it changes my RT and ET. I always ran 20lb in my bias ply slicks so I'm wondering if it will really change much.
'65 Mustang SS/L & L/SA
Old 12-23-2014, 03:52 PM   #13
Eric Merryfield
Eric Merryfield's Avatar
Liked 502 Times in 130 Posts
The Gremlin is lobbying me to invest in a set along with a set of rims since I didn't know about the 26 inch radial till today! Gremlin also runs 20-2 lbs, but I could see running 30lbs in the radial with ease. Tire weight increase is around 5lbs a piece for the radial versus bias.
Don't know how it would affect RT in a beast like the Gremlin, might slow it down dead hooking into a crowd pleasing wheelie of say a couple of inches, vesus the pro-stock style launch it sports with the bias.
Whats the best equipment out there for measuring vehicle reaction time currently?
Eric
Eric Merryfield 1883 STK
Old 12-23-2014, 05:18 PM   #14
7423
Eric
The best equipment is your time slip and the best fix is seat time, lots of it.
A practice tree will tell what your RT is. The rest is in your car. The average foot brake racer is .20-.25. Button boys are a bit quicker.
7423 is offline   Reply With Quote
Old 12-23-2014, 10:19 PM   #15
Joe DeMarzo
Liked 120 Times in 11 Posts
Ed & Charlie, I run 18 to 20 lbs in my bias depending on the track conditions.
Joe DeMarzo 1317 STK
Old 12-23-2014, 10:36 PM   #16
b.guggenmos
b.guggenmos's Avatar
Liked 3 Times in 1 Post
Is it still generally considered to not use a radial on a stick car and that they should be left on automatics? What makes me wonder is that with some of the small converters along with the high launch rpm and leaving from a trans brake they leave like a stick car. Hard. This should also apply to the reaction time question asked.
b.guggenmos is offline   Reply With Quote
Old 12-23-2014, 11:51 PM   #17
Ed Wright
Ed Wright's Avatar
Joe, mine is an SS car leaving with a Trans brake.
Ed Wright 4156 SS/JA
Old 12-24-2014, 09:31 AM   #18
Eric, Lebanon Valley Dragway has a vehicle reaction time setup that will tell you roll out. You have to mount a module to your car, and then an extra sensor that they have on the track will calculate the roll out of your car. It prints on the time slip. That is the most accurate way to determine the roll out.
www.portatree.com
Old 12-27-2014, 01:26 PM   #19
Dave Casey
Liked 797 Times in 165 Posts
It would seem that way, but the autos still are a fluid coupling, and don't hit the tire as hard initially. I have always had stick cars and the only time that I have used a radial was years ago when my Camaro ran L or M/S and I had a lot of wt and less power. It still loss in the 60 and 330 times, but made it up on the big end.
If there is any rt dif between the bias and radial, it certainly changes with the tire pressure.
Dave Casey 1330 STK
