Old 12-21-2014, 11:58 AM   #1
greatinspirational
Liked 30 Times in 14 Posts
Default Pulling trans from DF/S 91 Olds Delta 88 Help
Its almost ready to come out. I just need to loosen it from frame mounts but it looks like the frame running front to back drivers side is going to prevent the trans from being lowered out the bottom. It runs right along the edge of the pan. Is there a trick to getting the clearance to lower it out the bottom or do I need to bring the entire motor and trans out the top.
John Riley Jr
301 DF/S
greatinspirational is offline   Reply With Quote
Old 12-21-2014, 12:08 PM   #2
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: Pulling trans from DF/S 91 Olds Delta 88 Help
Support the engine from the top, there are hangers available to do that. Remove the entire cradle. Remove the transmission.
Old 12-21-2014, 03:39 PM   #3
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Thumbs up Re: Pulling trans from DF/S 91 Olds Delta 88 Help
I used to use those hangers with the Caddy but eventually found they weren't really needed. Support the engine with a jack, (not really needed) make sure you have pulled the axes and the trans will slide out. We used to change converters in 45 min. Jim
Old 12-21-2014, 04:23 PM   #4
Liked 5,146 Times in 1,964 Posts
Some of those cradles would split from corner to opposite corner..Not sure on that one.
You can use a hoist to support the engine too.
In any case, while it's apart, I'd make sure you have the clearance for the next time.
Old 12-24-2014, 12:24 AM   #5
greatinspirational
11
Old 12-24-2014, 10:16 AM   #6
ss3011
ss3011's Avatar
Hydramatic Motorsports supplied the original transmission for that car way back in the 90's. The gear sets from a THM 125 do not interchange with a 4T60. There were some high ratio sprockets made for the 4T60, these were made by Hydramatic Motorsports, and later were production, available for the Volvo version of the 4T60.
Old 12-24-2014, 12:11 PM   #7
Eman
Liked 133 Times in 76 Posts
Unless the frame has been modified it unbolts at the Rt. frt. You remove the bolts at the rt. frt. and the frame mount at the LF and LR and that half comes out. You have to break the ball joints to remove the axles easily. You can leave the L ball joint attached and swing the frame out, flat rate time saver. I use a support that goes from fender to fender and holds the motor up. You can make a support and use a long J bolt so you can hook the motor and raise or lower it, helps aligning everything.
Old 12-24-2014, 02:09 PM   #8
greatinspirational
22
Old 12-24-2014, 02:58 PM   #9
ss3011
ss3011's Avatar
A 4T40 might work well, I believe there is a case that will bolt up. Adapters are not legal in stock, unless approved by NHRA. Joel on Joy did the trans for Bill Owens Grand Am, so he has some knowledge of the 4T40. If you still have the original trans in the Olds, it actually has a higher numerical ratio trans, than what the 4T40 has, and uses a similar converter. I don't see much upside in changing the car to install a 4T40.
Old 12-24-2014, 08:24 PM   #10
greatinspirational
33
