Old 12-25-2014, 09:53 PM   #1
O.Devine
Default what convertor ?
I need some info regarding what convertor to use in a 3200 pound ss car with a 1.90 glide.
I currently use an 8inch but have slow 60 ft. et.
O.Devine is offline   Reply With Quote
Old 12-25-2014, 10:08 PM   #2
countrypuppy4865
countrypuppy4865's Avatar
Liked 228 Times in 70 Posts
Default Re: what convertor ?
3 speed tranny and need way more info than that to determine convertor. Engine dyno gives a good idea on what convertor it should like.
Jimmy "Cooter" Hidalgo, Jr.
4865 E/SA '04 GTO
4865 SS/GA '99 Firebird
Old 12-25-2014, 10:14 PM   #3
O.Devine
pulled off dyno at 850 h.p. @8000 rpm
Old 12-25-2014, 10:34 PM   #4
SS/ Modified car ?
Still need more info...Peak torque? @ ?
RPM in the lights. etc etc etc.
Old 12-25-2014, 10:49 PM   #5
O.Devine
612 torque @ 6500
launch 5500 trans brake
shift 9000
traps 9100 151 mph
I know there is no mysterious formula for this, but I am trying to figure if I need a 7inch convertor.
This is a SS/AS car
Old 12-25-2014, 11:05 PM   #6
Ed Wright
Ed Wright's Avatar
A1 has got the modified type stuff figured out really well. Call them with all the dyno info you have. I'm pretty sure it will be a 7" converter. I don't know that they build an 8".
Ed Wright 4156 SS/JA
Old 12-25-2014, 11:34 PM   #7
Originally Posted by O.Devine View Post
612 torque @ 6500
shift 9000
traps 9100 151 mph
This is a SS/AS car
Probably so.
Cubic inch? stroke?
Old 12-26-2014, 12:47 AM   #8
O.Devine
394 cubic inches
3.625 stroke
4.160 bore
8 inch ATI stalls. 5500 to 6000 depending on air
Old 12-26-2014, 01:15 AM   #9
ATI Performance Products
Sponsor
ATI Performance Products's Avatar
Liked 9 Times in 1 Post
394 cubic inches
3.625 stroke
4.160 bore
If you are turning 9k then 5.5 to 6k is way to tight. I am guessing the converter was not built for your current combo? Call the shop with the SN and we can check the build specs and tell you if there is room to loosen it up. If you do need a 7 in we will tell you that too even tho we don't sell them. A1 is a good choice for a 7 inch product for sure.
ATI Racing
ATI Performance Products is offline   Reply With Quote
Old 12-26-2014, 01:24 AM   #10
O.Devine
I did not mean to imply there is anything wrong with ATI convertors, I have won many rounds and a few races with this convertor,this convertor is really consistent, that is the reason I am looking for some info on convertors as I don't want to throw the baby out with the bathwater.
Yes this convertor was built for another combination but it was returned and restalled for this combination
ATI builds a great product, I absolutely would use them again.
