#11 |
Liked 783 Times in 195 Posts
Depends on the piston. A lot of piston configurations so not lend themselves to equal balance around the centerline of the pin. For example, BBC 396 high compression piston is unbalanced no matter what you do that is reasonable. You can add a lot of weight to the flat side of the piston to balance it, but is the extra overall weight infringing on the advnatge of minimum reciprocating weight? You can offset the pin, but it will take .150" to .210" offset to acheive balance.
Note: The above numbers were calculated using minimum weight Stock Eliminator pistons. You numbers will vary according to your restrictions. When I built the engine for the Corvette (SS) I worked to achieve a better balance relative to the pin centerline. Did it help? Who knows?!? A-B-A was not attempted, it just sounded good and trick to converse about in techno-savvy circles. I have seen pistons out of a very fast 283 SS engine that had the pin offset by .090"
#12 | |
Liked 99 Times in 49 Posts
#13 |
#14 |
Liked 7,829 Times in 1,750 Posts
Assuming that we are looking at the front of the engine in your picture, then on a V8 engine the drivers side pistons would be offset toward the intake side of the engine and the passenger side pistons would be offset toward the exhaust.
#15 |
That's what I thought, thanks.
#16 |
Liked 308 Times in 103 Posts
people use to turn mopar piston around backwards in old days was supposed to make them faster, the diagram posted is for quieter operation,isn't offset the opposite for power?
I would guess the taller the compression height of the piston,the more difference this would make? MikeTaylor 3601 |
#17 | |
Ed Wright 4156 SS/JA |
#18 | |
Liked 160 Times in 51 Posts
Most are import applications but you get the point. http://www.jepistons.com/Articles/10...d-Pistons.aspx
Brian Thompson NHRA Stock / Super Stock Class P/SA 6665 SS/MA 6665 |
#19 |
Liked 706 Times in 283 Posts
Anyone care to put a HP gain by doing this?
#20 |
Liked 334 Times in 181 Posts
HP Minimal---- if anything---RPM capabilities / rate of acceleration probably more due to to lighter piston weight but HP negligible
