Liked 1,471 Times in 308 Posts
What Transmission Fluid are you using in your metric 200?
Brand? Synthetic? Weight? And Why? Thanks. J.R. Haddad. |
Liked 109 Times in 32 Posts
I run Lucas Oil semi-synthetic fluid in my m200 trans. It's a great product and I've never had any problems with it. The Lucas trans fluid seems to protect the trans and converter as well, if not better than any other fluid out there.
The Lucas family also does a lot for sportsman drag racing so I like to support those that support us. Plus it isn't a super high priced product either! Drew Whalen |
Liked 140 Times in 51 Posts
In the 200R4 trans we run Dex 6, most builders are recommending it today. It is also backwards compatible with other Dex fluids
Kevin
The more people I meet the more I like my dog Kevin |
Liked 99 Times in 60 Posts
The comments from Drew also reflect my experience. The Lucas semi-synthetic ATF has given excellent service for me in several different combinations.
In addition, my experience with Lucas motor oils and gear oils is also very good.
Larry Woodfin 471W |
The race transmission builders I have used all recommended Type F.
Ed Wright 4156 SS/JA |
Walmart
Liked 33 Times in 16 Posts
Pretty much the cheapest Dextron I can find.
Rich Taylor I/SA - 321 |
Walmart Type F
$3.27 Quart
Guest
Posts: n/a
Allison Trans Synd in my Remac Trans. Handles heat real well, the auto 1-2 is very consistant. Warm or cold
I agree with post #6 #7 and #8. Unless it is something like a honda or a LATE model clutch to clutch unit, transmission fluid is not very specific.
