Old 01-20-2015, 01:01 AM   #1
oldskool
oldskool's Avatar
Liked 747 Times in 362 Posts
Default Bulletproof TH350 ?
I read that the A-1 Proflight 350-Strip Super Stock is one of the strongest TH-350 trannies made. But they are $6000.
So my question is, are there any of you guys who build TH350's that will live behind a long stroke engine with just over 700hp and about the same torque ?
Are some of the 9 sec SS guys using a TH350 ?
If you are one of these guys would you please post your info about the trans and who built it. Please include links to the builder, or contact info if available. Thanks !
Old 01-21-2015, 03:40 PM   #2
old tech guy
Default Re: Bulletproof TH350 ?
The A pro flight is a Chrysler torque flute developed by Dave Smith good for 1400 hp
old tech guy is offline   Reply With Quote
Old 01-21-2015, 04:37 PM   #3
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
The question should be what's fast and not what's strong........
You could almost get away with an AAMCO rebuilt TH-350 trans for 700HP if all you want is strong........
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 01-22-2015, 09:50 AM   #4
oldskool
oldskool's Avatar
Bob
I'll just assume that your statement is just an exaggeration. When I got my 1st 455 Pontiac engine I was not aware that 500ft lbs of torque would tear up a bunch of stuff.
A local racer had an 11 sec sbc Nova, with a TH350. He decided to switch to a Glide. So I bought his TH350. The TH350 had worked just fine behind his sbc. But that was because it had very little low end torque. But my 455 had about 500ft lbs @ 3000-3500rpm.
So, on the first 1-2 shift, it broke the int sprag race. So, I checked around and was told that big blocks needed a hardened sprag race. So, I bought one from TCI. I figured that would fix the problem. But apparently the hardened race was just more brittle. It broke into several pieces on the first 1-2 shift.
So, I had a another stock race put in it and sold it to another sbc racer. So to say a stock rebuilt TH350 will hold up behind a race engine with 700ft lbs of torque is ridiculous. If you can do it, fine. But 99 & 9/10 % of other racers can not get by with a stock rebuilt TH350.
There are several tranny guys who advertise TH350's good to 800hp or a little over. But I decided to ask some of you class racers about it. I assume that some of you guys with big block engines are making over 500ft lbs of torque and are using a TH350 to run a little quicker than with a TH400.
http://www.atiracing.com/products/trans/350/
http://www.atfspeed.com/store/index....x&cPath=193_53
http://www.coanracing.com/Catalog.as...uctDetail=1585
http://www.jakesperformance.com/TH350.html
On another site someone ask what tranny would hold up behind his 700hp long stroke Pontiac engine that will also have around 700ft lbs of torque. When I mentioned a TH350, several guys jumped on it saying "no way". Since I'd read on this site about you guys using TH200's and TH350's, I decided to ask about it.
The common upgrade I read about online is a 36 element sprag and drum assembly. Some even advertise a spagless set-up. So I just assumed that you guys would know who builds these HD TH350 for most of the SS racers that will survive high torque race conditions.
http://www.summitracing.com/parts/tci-327900/overview/
http://www.ckperformance.com/List/GM...missions/TH350
Old 01-22-2015, 10:00 AM   #5
Mike Pearson
Mike Pearson's Avatar
Liked 1,937 Times in 582 Posts
If you are bracket racing with the combo that you have listed in the previous posts you would be better off with a powerglide. The A-1 trans is referred to as a Protrans. These are typically light weight rotating assemblies for stock, Super stock and comp type racing. They are designed for max performance and not so much for max strength. Coan also makes a similar light weight turbo 350 its called the XLT. The cost is similar. I would talk to ATI,Coan or Rossler for a recommendation on the trans for your combo
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 01-22-2015, 10:05 AM   #6
Jim Kaekel
Liked 535 Times in 110 Posts
The 36-element upgrade for the intermediate sprag is the cure. Not a cheap upgrade, but it will prevent failure.
Jim Kaekel 3836 STK
Old 01-22-2015, 12:57 PM   #7
Jim Hanig
Liked 99 Times in 49 Posts
If its a bracket car put a 400 in and be done.
Old 01-22-2015, 01:17 PM   #8
Ken MacNicol
Ken MacNicol's Avatar
Liked 26 Times in 12 Posts
Agree
Ken MacNicol is offline   Reply With Quote
Old 01-22-2015, 06:27 PM   #9
Lou Jeffery
Smile Re: Bulletproof TH350 ?
I also agree 100%. No matter what brand you prefer Ford, Chevrolet, Mopar etc. The Turbo 400 is the Gold standard of automatic transmission. There are faster units but NONE better.
Lou Jeffery is offline   Reply With Quote
Old 01-22-2015, 09:20 PM   #10
Bob Mulry
Bob Mulry's Avatar
Bob
All a TH-350 needs is cut down Intermediate Piston to take 3 frictions, a 700R4 Lo Roller, a hardened or 36 element sprag and a shift kit................
and I did say almost.........
AND LAST BUT NOT LEAST
Start your burn out in 2nd or high gear to reduce the shock loading on the intermediate sprag
Bob
Bob Mulry 7516 STK
A & M Motorsports
