Old 01-23-2015, 08:11 PM   #11
L79racer
L79racer's Avatar
Default Re: drive shaft sensor 12 bolt rear?
Drew, you have a P.M.
Vinny
L79racer is offline   Reply With Quote
Old 01-25-2015, 09:06 AM   #12
L79racer
L79racer's Avatar
Im using an Ultimate ll tach wih the tach facts software. Can I use an eight magnet collar or do I have to use a two magnet one. What are the benefits of the eight magnet one?
Old 01-25-2015, 09:52 AM   #13
Cdncarnut
Cdncarnut's Avatar
Liked 56 Times in 31 Posts
With most sensors, of this type, every time the magnet passes the sensor, the magnetic field generates a pulse.
With two magnets, it would generate two pulses per revolution.
Eight magnets would generate 8 pulses per revolution.
The sensor does not care how often a magnetic field passes it.
The problem is that the data logger, in your case the tachometer, is going to assume that two pulses are one revolution.
So, with 8 magnets, your driveshaft is going to show that it is spinning 4 times faster than it actually is.
Thomas
NHRA 1959 D/SA
Cdncarnut is offline   Reply With Quote
Old 01-25-2015, 10:59 AM   #14
L79racer
L79racer's Avatar
Thanks for explaining Tom. Just ordered the 2 magnet collar.
