Old 01-26-2015, 10:12 AM   #1
4543
Liked 641 Times in 140 Posts
Default Batteries
I am needing to buy new batteries for the race car. I previously used 16V but am thinking of going back to 12V. What batteries out there stand up to the type of abuse drag racers inflict upon them? Any suggestions? Thanks
4543 is offline   Reply With Quote
Old 01-26-2015, 10:40 AM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,929 Times in 580 Posts
Default Re: Batteries
For 12 volt the Optima red top worked good for me. I would get 2-3 seasons from a battery. Why go back to 12 v?
Mike Pearson 2485 SS
Old 01-27-2015, 10:18 AM   #3
buzzinhalfdozen
Liked 11 Times in 8 Posts
If you've used 16 volt batteries before you must also have the charger, I second Mikes question...why would you go back to 12 volts? I've used the same XS Power batteries since 2007, never had an issue. I have a few people I know that have had issues with other brands, but not sure if was the batteries fault or improperly maintaining them.
Joe Buchanan SS/BX 3117
Old 01-27-2015, 03:37 PM   #4
Liked 10,714 Times in 2,230 Posts
For the money and the weight, keep in mind I weigh 300, the garden tractor battery works well from Walmart. I change it out each year. Yes my alternator works very well!
Old 01-27-2015, 04:08 PM   #5
Mike Pearson
I did the same in the past but used a very small car battery. I was afraid of the lawn tractor battery. No alternator but charged after each round. The small battery worked well. It was dying after a season and I put a regular battery back in. I am not as big as Larry but not small at all. 240+-
Old 01-27-2015, 07:40 PM   #6
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
I had an Optima red top in my car for 8 years. Don't know if Eric still has it. I always kept it on a good battery tender in between races and all winter. Also had the engine on a block heater all winter. Your results may vary.
Former NHRA #1945
Former IHRA #1945
T/SA
Old 01-28-2015, 05:53 AM   #7
4543
Thanks for the responses. I know that there are plenty of racers who run fast using 12V systems. I was primarily looking at the expense. Since the battery sits almost over the rear wheels in the Corvette weight is not an issue. I think I am going with the 16V XS.
