#11 | |
Liked 228 Times in 117 Posts
We just switched to Hoosier 30x9 radials. Cleaned wheel/tire bead with acetone & mounted dry. Tires are moving too much for my comfort. They are now cleaned with the same method & glued. Next races Mar. 15 & 16. See how they work this time. |
#12 |
Liked 11 Times in 8 Posts
I have seen the Mickey 275 tires mounted with the spray contact adheasive,but I have not seen when they were dismounted. My Hoosier radial drag slicks are mounted to Weld Wheels and screwed, with no problems,
#13 |
I run mine tubeless, no screws, no glue. Either mounted dry, or just wipe the wheel with a wet rag. I have marked them, and had them slip maybe a couple of inches first pass or two, then never move after that. My 60's are nornally 1.26 to 1.30, I often have to run them as low as 13 psi to get a green light.
Ed Wright 4156 SS/JA |
#14 |
Liked 225 Times in 88 Posts
Bobby , I have run radials with screws no problems .
