Liked 19 Times in 7 Posts
I was thinking of building a 5.3 LS rated at 305 for a super stock GT combination. It looks like I can use the 243 or 799 heads which I think can have flow numbers better than 300. My question is if this is a good combo to build and is the Throttle body large enough to support over 650 hp. I was thinking of putting it in a Nova for GT/GA at 3400lbs.
Any thoughts would be appreciated. Henry Sliwinski 5774 SS/HA |
Liked 6 Times in 4 Posts
What RWD car was the 5.3 LS installed in from the factory? And where is the 5.3 listed at 305 horsepower?
I don't think there are any RWD cars but I was looking at the 2007 impala engine. Since aftermarket blocks are allowed could it not be used?
I don't think there are any RWD cars but I was looking at the 2007 impala engine. Since aftermarket blocks are allowed could it not be used? Sorry it is rated at 303 hp.
Liked 130 Times in 42 Posts
I've been wondering about this combination..
Liked 112 Times in 31 Posts
Don't know about the block situation. But the heads flow great. We've had a couple sets on the bench that we've done flow over 300cfm @.700 without getting really crazy with them with the stock size valves. Could be a pretty interesting combination I think.
Rick |
Liked 18 Times in 4 Posts
Removed
Bryan Broaddus 7568 STK ,SS |
I think the aftermarket block would be my choice on this build. and the heads have great potential. I am just not sure if the throttle body can support the airflow demands. Maybe a sheet metal intake can overcome the throttle body size. I would like to see the motor make between 680 to 700 hp. I think the heads can support that, the question is the other components. I think peak power may be in the 7800- 7900 range.
Liked 308 Times in 103 Posts
If you are talking 300@28'', if throttle body and intake don't cut back air flow, I calculate around 611 HP @ 8759 rpm, this is calculated using superflow's formulas for HP and peak rpm for HP based on airflow and cubic inch.
Mike Taylor 3601 |
Thanks Mike, I forgot about those calculations. I have used those in the past and I have found that you may have to multiply the horsepower by the volumetric efficiency to get close to real world numbers. The rpm side was usually close. I didn't think with the longer stroke of the 5.3 that it would need to rpm that high.
