Liked 444 Times in 145 Posts
Small Block 350 Chevy:
10 runs Pair of 993 heads all best parts by Whitaker: $2,250.00 Short Block, +.065 bore, Coated CP Pistons, Total seal Rings, Bushed lifter bores with Schubeck Lifters, latest Bullet Cam, $1950.00 Intakes, 771,751 and 469 all professionally cleaned $275.00 each Used ATI Balancer: $225.00 Also many more intakes, both two barrel and four barrel for 71/72/73 motors: $50.00 each Vic Junior: $95.00 One bone stock Aluminum intake for 69 302/350: $495.00 Stock heads with original valves in place: Pair of 487 $275.00, Pair of 487X $325.00 Fresh Metric race transmission, forward pattern, $1,150.00 Fresh metric Torque converters: $275.00 each 350 Bracket motor, long block (everything but intake), TRW pistons, 993 heads with 2.02 Valves and Lunati crank: $1550.00 350 short block, Stocker 71/72 combo's, Ross pistons, Total Seal Rings, good Comp cam, Block has minor repair but still running strong when I built the 73 combo. Should be freshened: $1,150.00 Chevy Big Block: Aluminum Intakes: Two 359's for 454: $375.00 each One 163 with cut plenum for All Big Blocks $325.00 Big "School Bus" Pan for Big Blocks. Cleaned with trap: $275.00 Big Block Buick 455 Block, cleaned deburred and magnafluxed. It's meant to be the premo block: $475.00. Two pairs of Stage one heads: Cleaned and magnafluxed: Not sure what they are worth. Assorted parts: Two Holroyd Holley carburetors: Very nice condition. Cost $1,000.00+ each but will sell for $575.00 each. Two like new Moroso 24" x 15" tires, eight passes on them $175.00 for pair Two new Weld Aluma Star rear wheels: Slicks were monted on them but they would not fit my car. The slicks were removed and the wheels put back in boxes. GM pattern with 3 1/2" back spacing: $425.00 for pair. New in box FluidDampr for small block Chevy: $175.00 NOS Camaro Hood, 70-81 with GM Stickers still in place. Three very small blemishes: $775.00. Yamaha Generator - 6,500 Watt in great condition. These generators are selling for over $3,000.00 new. Will sell for $995.00. All prices exclude freight: Thanks for reading and Merry Christmas!
Bruce Noland 1788 STK |
Liked 1,470 Times in 308 Posts
Bruce, tell me about the torque converters, what motor were they behind, stall, shift points, fall back, etc. Merry Christmas!! J.R. Haddad.
For 350 270 motors. About 420 HP, at 3,450 pounds. All of them in the 5,150 - 5,200 range. Depending on gearing and class, I would shift at 6,500 and then 6,800 usually dropped back about 800 rpm. One PTC, two Dynamics and one AT I. The AT I is probably sold.
Liked 780 Times in 194 Posts
Bruce - is it a flat top piston short block?
Liked 5 Times in 4 Posts
Bruce , does the short block have c-19cp
pistons for the 73 model rated at 287hp . Thanks |
The short block is for a 350/270 dish piston motor.
Bruce, you need to clear some space to accept P.M.'s.
Thanks, J.R. Haddad. |
Hi Bruce,
I'm interested in the 10 inch wheels. Please contact me at flowbenchguy@yahoo.com or call Seven12 three63 threeeight01 Thanks,] Jon Jamison |
Liked 53 Times in 17 Posts
Info on the generator please.
Sorry guys. I thought this ad was burried. The ten wheels have been sold and I sent a pcture of the generator to zenzen. I will try to do a better job of keeping up with this ad in the future. Thanks.
