#51 |
Liked 32 Times in 19 Posts
The DR525 is the one I referred to in my discussion. A 350 I believe. Are all the three motors you refer to supposed to run together? or separate classes?
#52 | |
Liked 5 Times in 5 Posts
That class is already out there, it's call Superstock GT. I admit I'm an older guy and would love to see a modified type class created nowadays for those that would want to get involved, myself included. Bryan, I respect your opinion, but personally I wouldn't want to see dragsters included here, there's plenty of places for those cars. I hope this thing takes off. It won't be easy at the start, but it should evolve, participants willing. I'll keep my fingers crossed. Danny Durham |
#53 | |
Liked 61 Times in 25 Posts
It is actually a 376 c.i LS3 engine. The plan would be for the NHRA to run them all together, heads up. Weight and tune, (tune provided at the track, by sanctioning body) can be adjusted to keep playing fields level. The Ford is down by about 120 hp, compared to the Chevrolet, but minimum weights are less for the Ford. Here are links to the 2 engines, as sold by Summit and Jegs http://www.summitracing.com/parts/fm...Fe7m7AodLF8AdQ http://www.jegs.com/p/Chevrolet-Perf...17524/10002/-1 Last edited by Tony Corley; 04-04-2015 at 07:47 PM. |
#54 |
Liked 2,359 Times in 557 Posts
The DR525 is 376 ci. At this time, the CP/S and C/S classes are run separately (NMCA/NMRA). They may run the classes against each other at Joliet later this year, but I am not 100% on that. Chrysler does not offer anything for this type of racing.
#55 |
#56 |
I reviewed the rules. They sound very restrictive and complete. No wonder they are being built for fun. Seems at one reading someone put a lot of thought into all the fine points to keep it minimalist.
Only issue that can be raised is only one brand which personally is fine but thought of Econo Mod was to include ALL by using Same lb per cubic and Brodix spec heads which are VERY close to same flow for all brands... |
#57 |
You must have only read one set of rules. There are 2 sets I linked. One for Coyote Stock, and one for Chevrolet Performance Stock. The same premise could be followed with Chrysler to include them. They also have several crate engines that are similar in hp to the Chevrolet and Ford.
#58 |
Liked 227 Times in 74 Posts
A CS build on another site http://www.yellowbullet.com/forum/sh...light=maverick
I watched the CS at NMRA at Norwalk and was impressed nearly every car had a 4 or 5 speed and it was a fun class to watch BUT Stock has soooo much more variety with Chargers GTOs older mustangs etc could you make a larger older car such as a chevelle,charger,gto etc compete against a sea of mustangs in this class? Im not racing a fox and be like everybody else!!!!! |
#59 |
In the Chevrolet Performance rules, they have made the minimum weight higher so that older cars will be more competitive. Think they also get a slight weight break, and a few concessions chassis wise. The Coyote Stock class has some concessions also for the older cars, there are just so many Fox Bodies that were laying around, that's what most are running.
Obviously, if NHRA were to pick up something like these classes, adjustments could be made to make certain the older cars were just as competitive as the new. I never said these rules should be used verbatim, just showed how simple they were. |
