Liked 994 Times in 200 Posts
Can you use quadrajet jets in a rochester 4 jet carb?Been a while since i worked on one. thanks
Liked 99 Times in 60 Posts
Lyn,
I do not know the answer about jet size. What I do have is one mid 60's Rochester 4 jet. If there is a desirable style I will check what I have. If you can use it pay the shipping.
Larry Woodfin 471W |
Liked 354 Times in 120 Posts
Lynn the jets work but if you look at them the 4 jet is flat in the center the q jet is tapered or other way around, so they flow different. If you change from one to the other you may not be changing anything at all. I know that you can get them for a Holley but does anybody know where you can get jets flowed. Tom
Tom Meyer 5240 SS Stock ??? Last edited by Tom Meyer; 04-12-2015 at 10:27 AM. Reason: added |
Lyn, The Q jets are tapered to accommodate the primary rods
Otherwise interchangeable...1/4 28 thread
"We are lucky we don't get as much Government as we pay for." Will Rogers Last edited by Mark Yacavone; 04-12-2015 at 02:26 PM. |
Thanks for the info and help.
Liked 783 Times in 195 Posts
Not all 4gc jets are flat across the inside. There were three different designs over the years - one was flat, one had a small 45 degree chamfer at the top and the third had a large 45 degree taper cut that extended half the distance of the jet body. All had different flow characteristics so it is imperative when tuning that the same style jets is used when changes are made. Qjet jets will fit, but you may have to experiment with sizes to get the correct fuel-air mix if you have references from one of the 4gc jet styles.
Thanks Dwight, I knew there was some different ones just not that many. What is going to happen when all this info will be gone? I hope someone is taking notes. Tom
Tom Meyer 5240 SS Stock ??? |
That's why we're here,Tom.. Puttin' it all out there in the archives..
they are different, I wouldn't use but only the same
if you need a different jet, use what yu have a drill out if going larger.
