Old 04-17-2015, 11:21 PM   #1
HP HUNTER
Liked 373 Times in 129 Posts
Default Rotational Weight Question
Lets say you have C/SA 69 Camaro 375/396, If you ran a conventional 12 bolt with a steel spool non gun drilled axels and ran 10.50 with 1.36 60 foots, if you built a 12 bolt with 35 pounds less rotational weight and ceramic bearings, how much would you pick up?
Old 04-18-2015, 02:08 AM   #2
GTX JOHN
Default Re: Rotational Weight Question
I think if you picked up .01 in 60 that would be a lot.
John Irving
741 Stock
741 Super Stock
Old 04-18-2015, 07:10 AM   #3
Ed Wright
Ed Wright's Avatar
I put an aluminum spool and lightened gear set in mine, and found nothing. I don't waste my money there anymore.
Ed Wright 4156 SS/JA
Old 04-18-2015, 08:07 AM   #4
Tom Meyer
Liked 354 Times in 120 Posts
My thoughts are, you could pick up more by having your rear end square in the car and all moving parts on it move smoothly with no binding. The right lube and how much is also important along with having the gears properly set up. I also don't think you could get 35# out of a 12 bolt and if you could all that it would help would be sprung unsprung weight. Tom
Tom Meyer 5240 SS Stock ???
Old 04-18-2015, 09:26 AM   #5
HP HUNTER
What lube do you run?
Old 04-18-2015, 09:30 AM   #6
HP HUNTER
Do you think a foot brake combination might have different results? I appreciate all opinions, just trying to learn.
Old 04-18-2015, 09:54 AM   #7
tj310
I remember a saying that was attributed to Colin Chapman
A gram of reciprocating weight is worth an ounce of rotating weight
an ounce of rotating weight is worth a pound of chassis weight
Take that with a grain of salt. ---Trevor
Old 04-18-2015, 02:36 PM   #8
FED 387
Liked 333 Times in 180 Posts
I was always told that rotational weight is equal to 4 times the actual weight---- that means that for every pound the effective weight that the engine is trying to overcome would be 4 pounds--- now this may depend on how great the diameter of the object is--- in other words if you have an item that is 2 inches in diameter the rotational weight difference will not be as significant as say an item that is 12 inches in diameter where it should be greater--FED 387
Old 04-18-2015, 04:24 PM   #9
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
I asked this before. I was told to spend my money under the hood. All that crap isn't worth .05
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 04-18-2015, 06:06 PM   #10
james schaechter
I think if you have the car flogged out, tuned out and drive it perfectly every time, buy that stuff. I do think it can help over time,but it is never one thing, it is all of the things. If there is no more HP to be had, start there. If you can't make minimum weight and you can save unsprung weight why not?( expensive though) You need the good stuff though. I have heard of guys trying some aluminum spools and the deflection hurt more than any weight savings. If you are not hampered by any pesky performance rules, just hop up the bullet. I agree, very small gains for big money. Walk the Comp pits.mthose guys know.
James Schaechter 3163 STK
