Old 05-25-2015, 10:10 PM   #1
racer913
Default Best oil pan gasket
Looking for suggestions for best oil pan gasket for a milodon 31167 pan and any any tips such as adhesive
racer913 is offline   Reply With Quote
Old 05-25-2015, 10:19 PM   #2
Liked 1,914 Times in 429 Posts
Default Re: Best oil pan gasket
Engine?
Old 05-25-2015, 10:31 PM   #3
racer913
434 small block chevy
Old 05-25-2015, 10:37 PM   #4
Liked 5,147 Times in 1,964 Posts
http://www.speedwaymotors.com/Speedw...ece,33723.html
Old 05-25-2015, 11:34 PM   #5
I've had the best success with the one piece molded FelPro oil pan gaskets.
Old 05-26-2015, 08:51 AM   #6
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 312 Times in 105 Posts
With 4'' stroke might want to look at fel-pro 1821 has steel insert and is notched to clear rods, sealer I use permatex ultra black or ultra grey and another tip is get a tube sqeezer from Valco you can lay perfect beads of silicone and use practically every drop in the tube
Mike Taylor 3601
Old 05-26-2015, 02:03 PM   #7
Eman
Liked 133 Times in 76 Posts
I've used Fel-Pro and it leaked at the frt. of the pan with my Milodon pan. I talked to Milodon and bought their pan gasket and it also leaks at the frt. It doesn't pour but it's always got a little oil around the edge. I'd use ultra gray or black on the ends to be sure.
Old 05-27-2015, 08:21 AM   #8
Mike Taylor 3601
Many aftermarket pans leak around front and rear gaskets,I have sealed many of them by taking dull chisel,piece of flat bar etc. and tapping with hammer to make them fit,with pan bolted on. I have worked on the front with engine running and can watch and see the results,the rear not going to attempt that,with engine running.
Mike Taylor 3601
