Old 06-07-2015, 09:53 PM   #1
rboyle
rboyle's Avatar
Liked 586 Times in 162 Posts
Default Stocker Tech Rules Gas Tank & Battery?
If you use a stock mounted battery location are you allowed to modify the tray and hold down to prevent the battery from tipping or moving around? Lastly if you use a stock tank can you modify it too for a sump and smaller actual tank capacity? If not can you use it to cover the bottom half of the fuel cell so it still looks stock from behind and underneath? Thanks in advance for the input.
Old 06-07-2015, 10:31 PM   #2
GTX JOHN
Liked 2,487 Times in 698 Posts
Default Re: Stocker Tech Rules Gas Tank & Battery?
Yes to battery mounting. In fact you need 3/8 metal holddowns and to replacethe open J hooks that are usually the factory mounting. I have never heard of the gas tank sumps being illegal.....but why not have the safety of a fuel cell instead of all that work on stock tank?
John Irving
741 Stock
741 Super Stock
Old 06-08-2015, 10:38 PM   #3
MikeMoller
MikeMoller's Avatar
Liked 254 Times in 78 Posts
NHRA 2015 Rule book under Stock
GAS TANK
Must be correct year, make, and model for car used, with stock
fuel inlet and outlet locations. Must be in stock location; fuel line
and pickup may be resized. Fuel cell permitted; maximum capacity
16 gallons. If fuel cell is used, OEM gas tank must be removed,
and a firewall of minimum .032-inch aluminum or .024-inch steel
must be installed to totally seal driver compartment from fuel cell.
Trunk floor may be modified to accommodate fuel-cell sump.
Where OEM gas tank is in the trunk floor, area occupied by OEM
tank may be replaced with material equal to or heavier than OEM
floor. If OEM gas tank is used, it must remain unaltered.
Mike Moller
NHRA 203 Q-R-T/SA
Old 06-09-2015, 09:37 AM   #4
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Based on the rule, he could probably use the material from the bottom of the OEM fuel tank to fill the hole vacated by replacing it with the fuel cell. Use the bottom of the tank as the "equal or greater thickness" fill material. This is Call the Tech stuff, though.
Dale
Dale Shearon
68 Mustang 6394
Old 06-09-2015, 10:08 AM   #5
Dave Ribeiro
Liked 56 Times in 27 Posts
Thumbs up Re: Stocker Tech Rules Gas Tank & Battery?
rboyle,
Save yourself a lot of time & money ? Call Ryck Campbell @ 315-335-8295,
7-9 PM Mon-Thurs. He will help you with the right answers , he's the Div. 1 tech guy .... Do it right the first time, its much cheaper !!! LOL
Dave Ribeiro 1033 STK
Old 06-09-2015, 05:37 PM   #6
Geerhead55
Liked 5 Times in 5 Posts
Cool Re: Stocker Tech Rules Gas Tank & Battery?
GAS TANK
IF OEM tank is used it MUST remain UNALTERED,,, seems simple to me.
Danny Durham
Old 06-10-2015, 12:31 AM   #7
FED 387
Liked 333 Times in 180 Posts
the way I read the rule is if using a stock tank you are only allowed 2 MODIFICATIONS to the tank you can RESIZE the fuel line & the pickup--- it says nothing about sump areas in a stock tank being allowed that I would consider a modification--- NO OTHER MODS ALLOWED--- now if you use a fuel cell many times a sump area will be molded in as part of the design so you will be OK and in addition you must fabricate a metal barrier between the cell and the passenger area---my take on it-- FED387
Old 06-10-2015, 05:33 PM   #8
Geerhead55
Smile Re: Stocker Tech Rules Gas Tank & Battery?
I hear you,, if you're going to resize both the fuel line and pickup,, you'd want the correct fittings to finish the resizing,, therefore modifying part of the tank,which is not allowed, so they've created a "grey area" once again, in rules interpetations. I'm not going to tell anyone how to construct their own car,, but if its me,, I'm going with a fuel cell, putting this behind me and moving on to the next area of construction. My 2 cents.
Danny Durham
Old 06-10-2015, 11:46 PM   #9
No comment on part 3 so here's mine:
Gas tank shields were used as far back as the 60's..sometimes as a good way to add weight
(C/FX cars, etc.)
I don't see any good reason why you couldn't fab one out of a gutted oem tank, and securely mount it to shield the bottom of the fuel cell and it's fuel lines.
Of course if you ask ,rather than just doing it, I'm sure the answer would be no.
Old 06-11-2015, 08:36 AM   #10
Bobby DiDomenico
Liked 101 Times in 52 Posts
Saw this installation at a cruise night. Pretty scary.
On a car where the factory gas tank is the trunk floor, do they require you to install a metal barrier?
Name:	Fuel Cell 20150610_194151.jpg
