Liked 11,029 Times in 2,266 Posts
After reading the rule book for the umpteenth time, I realized that I had my fuel pump wired wrong. The pump would not stop when the ignition switch was turned off. The wiring has been corrected.
Check your stuff and be safe. |
Liked 237 Times in 126 Posts
I'm in the habit of using my master cutoff. I added a lever next to the shifter with a Morse cable back to the battery switch like Woodfin. I'll try the ignition switch on the panel today when I move it in for pain touch up just to make sure it works that way too. Thanks for the heads-up.
Dale
Dale Shearon 68 Mustang 6394 Last edited by FireSale; 06-30-2015 at 10:52 AM. |
