Old 07-13-2015, 11:50 AM   #11
Mike Pearson
Mike Pearson's Avatar
Liked 1,937 Times in 582 Posts
Default Re: Starting line hesitation
Originally Posted by Monte Howard View Post
Since Danny built it, I am ruling out the air door to loose. I would try a new choke pull-off, I have had several of them go bad and cause the same issue. Pull the vacum hose off and push the arm in, with the arm pushed in hold your finger over the vacum port. Let go your finger off the vacum port and make sure the arm comes out smoothly. If it starts coming out and then hangs up for a second it's bad.
Let us know if you figure out the stumble in your carb. We have a Danny Ashley prepared Q jet that does the same thing and we have not been able to get it fixed. It's a real nice carb and Danny does nice work so we would realy like to get it running right.
Mike Pearson 2485 SS
Old 07-13-2015, 12:42 PM   #12
DIV3CR
Liked 3 Times in 1 Post
In the instruction from Danny that come with The carb it said
that the brass plate fit in a machine groove in the carb top
and I have double check the plate and it is in the groove.
If I find a answer I will post it.
Thanks for everybody's help
Bob Keller
DIV3CR is offline   Reply With Quote
Old 07-13-2015, 12:52 PM   #13
njk53
Don't you guys think 6 psi. of fuel pressure is a bit low? We had a Dean Oliver prepared carburetor and currently have a Hedworth prepared unit and we ran both carbs. at 7 psi. and both perform nicely. Is it possible momentary fuel starvation is occurring considering a Q-Jets float bowl is so small?
Just a thought.
Nelson Kowal
Stock 345
Old 07-13-2015, 01:26 PM   #14
Mike Semeniuk
Mike Semeniuk's Avatar
Liked 6 Times in 2 Posts
Fuel Pressure is related to the size of needle and seat, and float settings and of course demand. I need to run mine at 5.5 for best operation , anything over 6 and - too many issues
Mike Semeniuk 632 GTMA
Mike Semeniuk is offline   Reply With Quote
Old 07-13-2015, 01:37 PM   #15
Mike Pearson
Mine runs good at 6 lbs too.
Old 07-13-2015, 02:00 PM   #16
Cdncarnut
Cdncarnut's Avatar
Liked 56 Times in 31 Posts
I am running a Joe Scott at 7 psi with no issues.
My Ashley was also running at that same pressure.
Thomas
NHRA 1959 D/SA
Cdncarnut is offline   Reply With Quote
Old 07-13-2015, 02:09 PM   #17
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
I have run ours at pressures of 6 to 7.5psi without issue...currently at 6.5psi.
Rich Taylor
I/SA - 321
Old 07-13-2015, 06:29 PM   #18
Liked 5,125 Times in 1,953 Posts
I'm really not getting how you could bind up that secondary plate deal.
The last thing you would do is set the metering rod tips down into the fixed jets.At that point the hanger would be down flat on the cam arm. You can slide the whole deal fore and aft to check everything before you put the hanger screw in place.
Danny did a nice job on that deal. I never did get that fancy. I just took a small chunk of a Walmart bag and cut a couple of x's in it, then stuck it down to the gasket with a spot of chewing gum until I got the top was screwed on.
That works fine ,and doesn't restrict or bind the swing of the rods like the old tape trick did.
Old 07-13-2015, 07:41 PM   #19
Joe DeMarzo
Liked 113 Times in 9 Posts
Just in case... check the accelerator pump. Every time mine hesitates or stumbles off the line the gasket is dried out from sitting, torn or worn out and doesn't seal because of VP eating at the gasket. Q-Jets do not like a lot of fuel pressure so 6 to 7.5 is fine. You can play with that but not is why it is hesitating in my opinion. Let us know so we can learn, Q-Jet are great but can make you crazzzzy.
Joe DeMarzo 1317 STK
Old 07-14-2015, 08:28 AM   #20
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 307 Times in 103 Posts
I would say your gasket is bad like Joe said, or needle and seat is leaking. My car has done that before,finally figured out it was needle and seat, I have them leak,but they don't pour fuel out of it,they will leak slightly,car will idle about 200-300 rpm slower,and bogs a few feet out.
The best test I have come up with is remove top and hold float pivot rod with your finger so float works like the top is on carb,then have someone turn on fuel pump, after needle and seat closes watch fuel level in bowl for 1-2 minutes,it should not creep any higher up at all,it may take a minute and if leaking will rise very slowly, be careful sometimes when first turn on pump it will spray fuel out,I usually use my other hand as a shield over carb,till it calms down.
The best thing I have found to prevent this problem is to run carb dry and pump fuel out of tank when I get down racing and store the car,even for one week.
Mark,
I still use the tape trick, I use 3M super33 tape is a soft and flexible electrical tape.
Mike Taylor 3601
