Old 07-16-2015, 12:58 PM   #21
Rusty Gillis
Rusty Gillis's Avatar
Liked 87 Times in 19 Posts
Default Re: GT class configuration...
Dwight this is a great tool and maybe I'm missing something but what if you have a replacement head and NHRA has added hp how do you look that up?
Rusty Gillis
Former NHRA SS/FA and SS/GA record holder
Rusty Gillis is offline   Reply With Quote
Old 07-16-2015, 02:20 PM   #22
Liked 5,121 Times in 1,952 Posts
Does anyone see a button for GT Classes? I don't. I have emailed Dwight.
Okay I see it now. You have to click on the specific p/w factor for the body style and engine to be used, the negotiate from there.
I see , for instance a 66 Chevy II, 2 dr sedan with a 283 , can run three classes in SS, but five classes in GT. Then if the hp rating is lower in GT, you can get back to the weight break where you were in SS , at a lighter weight than when you left, with the same index.
Does this make any sense to anybody?
Also , seeing GT class was formed to allow a different year engine than the body you are using, would you have to claim the 283 as a 65 engine, or don't they care about that either?
Old 07-16-2015, 02:55 PM   #23
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Mark,
Where you need to pay attention is the min and max combo weight calculations in GT, as you are only allowed to be 250lbs above and below the natual class, at least that what I have found. It's a very helpful tool to play with what combo's could work, and what not to build! Dwight has really made looking at combos very easy.
Thanks Dwight!
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 07-16-2015, 02:56 PM   #24
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
Mark -
Current rules do not require that the engine be a different year, so the guys with the Chevy IIs that run GT/K and L are just using the option to run a softer index with the same weight.
Old 07-16-2015, 02:59 PM   #25
Dwight Southerland
Rusty, what is the combination you are looking for?
Old 07-16-2015, 06:34 PM   #26
Rusty Gillis
Just about every engine that I could use in my 1967 Fairlane or 1969 Mustang with aftermarket heads has hp added. I know how to look it up on NHRA's site and today was the first time I looked at your site and was surprised that it was only listed with stock heads. It is a lot easier getting aftermarket heads when building these classic cars. I want to say again that you have done a great job putting this all together.
Rusty
Rusty Gillis
